my cluth seems to have went out
Old Oct 27, 2006 | 08:33 PM
choppin_civic's Avatar
Default my cluth seems to have went out
my clutch seems to have gone out, i have no pressure in my pedal, car wont shift into gear when engines running etc...the usual symptoms i was wondering if anyone knew a way to "rig" a repair until monday where i can actually get my clutch, this is my only car and i cant afford to not have it working
Old Oct 27, 2006 | 08:43 PM
John M's Avatar
Default Re: my cluth seems to have went out (choppin_civic)
sure it isnt the mc
Old Oct 28, 2006 | 03:02 PM
Default Re: my cluth seems to have went out (Teal-EJ1)
yeah im pretty sure it isnt the master cylinder im almost positive its my clutch but i just need a quick fix until monday when i can grab a new clutch
Old Oct 28, 2006 | 03:10 PM
bmoua's Avatar
have you checked your slave cylinder??
Old Oct 28, 2006 | 03:56 PM
stock_honda_coupe's Avatar
Default Re: (bmoua)
If it happened suddenly then its probably somewhere in your hydralic system. theres not really any temperary fix. you'll need to replace whatever is bad.
Old Oct 28, 2006 | 04:02 PM
ek_chris's Avatar
check for brake fluid on the floor (a leak). Check your resevoir level as a friend is pumping the pedal several times, see if the level drops. It's not your clutch if it wasn't burning/slipping prior.
Old Oct 28, 2006 | 05:15 PM
bsixteen's Avatar
has it been slipping lately? unless you were ragging the hell out of it it just doesn't stop working 1 day.
Old Oct 28, 2006 | 10:01 PM
Default Re: (bsixteen)
yeah it has been slippin lately which is why im 99% sure its the clutch i was just curious about a quick fix for the weekend but thanks everyone for all ur help
Old Oct 29, 2006 | 01:03 AM
turnsignalandy's Avatar
Default Re: (choppin_civic)
My freinds slave cylinder went onut on his 89 teg. His car would burn out if he revved it past 3k, and he barly made it over a 2% hill. Basically he had to drive a 15mph, for about 8 miles..........
jlowellintegra
Nov 27, 2010 08:15 PM
EddieLe76
Jan 14, 2010 01:50 PM
fcjohnny
Nov 19, 2009 07:33 PM
88aeFC3S
20
Apr 13, 2009 03:48 PM
eg6sittingon57cs
Aug 8, 2007 10:44 AM
