Resonator Box.. Lose power if removed?
I pulled mine out over the weekend and have heard that I will lose power and that I will not lose power... funny how so many people believe the opposite on such a thing.
I plan on pulling the tube out of the resonator box and attaching it to the filter box, or just getting a Comptech Icebox and putting it in there...
I wish the archive search worked better.
I think it was determined that the box is "tuned", and allows the intake air to pulse or something like that.
[Modified by jond, 12:19 PM 5/6/2002]
Don't base your decision on a 2-3 hp dyno difference. It is common to see 2-3 hp variances from one run to another with the car untouched!
Yeah, pull the resonator and run one of these down to behind the turn signal, cheap and easy:
Good butt dyno gains, stronger pull in the midrange and no loss up top, smooth VTEC crossover, a little louder than stock yet sounds really clean and smooth...
M
M
Like #700 says, do your own ice box, here is a step by step instruction :
http://www.geocities.com/bretq/DIY_Icebox_CAI.html
Or send $30 to Bret if you don't want to take the time to do it.
Add a K&N drop in, and performancewise you should be very close to the comptech set-up.
It also has to advantage of looking stock
I don't have any Dyno, but I can not believe that removing the resonator only and sucking hot air a few inches from the header could be a good thing. It is just common sense to me...
AEM CAI works well...
Or just make your own ice box like a couple people on this board did.
that can design the piping to its desired airflow pattern. I promise you that figuring out to keep flow to be laminar or turbulent is not an easy task.Unless the DIY Icebox have this in mind during its design, then $30 is a steal.
[QUOTE]I don't know about hacking the stock airbox and making your own.[QUOTE]
Umm, there is NO hacking needed, a simple 20 minute install, if that, all bolt on...
Thanks.
M
Thanks.
M
I dunno I had an AEM and I saw the make it yourself Ice Box instructions and went to work one day on it, installed it, then sold the AEM the next day to a ricer down the street for $150.
I will never go back!
I don't know about hacking the stock airbox and making your own. I am sure that AEM and Comptech have some comptenent ME's or even ChE
One last thing, the "Icebox" only requires the removal of the stock resonator and insertion of the intake tube. No "hacking" is required to the stock airbox or resonator.
Bret, if can dyno your DIY kit, they will definitely sell like $1 draft beer on Octoberfest. You can then sell your kit for $35-$40 to make up the cost. I for one will get one since the Icebox quality is not near OEM in terms of quality of material and finish. The fact that the cover snaps on, instead of being held by screws bothers me.
i removed mine last night and broke the resonator box and took the black tube out of it and ran it under without the resonator box..... I like it..... i feel alittle more midrange pull and its alittle bit quieter. But i like it.....
just wanted to share..... hope this helps
thomas
thomas
Flux
May 7, 2002 08:22 AM
