Any harm in a little loose valve clearances?
Old Oct 27, 2006 | 06:44 PM
miksew's Avatar
Default Any harm in a little loose valve clearances?
I did a valve adjustment for the first time and I believe I may have adjusted them a little on the loose side as I did not have an angled feeler gauge and I didn't have the correct sized gauge that the manual calls for but a size a bit larger.
Can I drive like this safely?
Old Oct 27, 2006 | 06:50 PM
EG2Driver's Avatar
Default Re: Any harm in a little loose valve clearances? (miksew)
well as long as its not too far out of spec, yes. It is better to be on the loose side than tight, because if they're too tight, you might burn ur valves.
I didnt use angled feeler guage and mine didnt turn out so great either. Im going to purchase a real nice set of angled when i get a chance before this winter. You should too.
numotive
Oct 6, 2016 06:57 PM
spidermancivic
Dec 2, 2005 11:21 PM
_Endless_
Jul 7, 2004 06:24 AM
SIRBUSH
Oct 15, 2002 08:04 PM
Mugen Dom
10
Jul 29, 2002 02:20 AM
