HELP!!! PASSENGER DOOR WON'T LOCK!!!
Old Oct 27, 2006 | 03:03 PM
LvN's Avatar
LvN
Default HELP!!! PASSENGER DOOR WON'T LOCK!!!
My friend's 00 Civic won't lock on the passenger side. We took off the door panel and everything is intact. Whether we manually lock it from the inside or outside or alarm, the door just won't lock.
Old Oct 27, 2006 | 03:33 PM
Thizzed Out's Avatar
Default Re: HELP!!! PASSENGER DOOR WON'T LOCK!!! (blkcivicpn0i)
open the door then pick the handle up, and lock it manually
Old Oct 27, 2006 | 03:41 PM
GSaura's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i &raquo;</TD></TR><TR><TD CLASS="quote">My friend's 00 Civic won't lock on the passenger side. We took off the door panel and everything is intact. Whether we manually lock it from the inside or outside or alarm, the door just won't lock.</TD></TR></TABLE>
What do you mean, "everything is intact"? It should work if everything is intact. You need to look more closely, man. Look at where the rods hook into the latch at the end of the door. Maybe one of those plastic tabs popped loose or broke. Is it an aftermarket remote keyless system? Make sure that the lock rod travels the appropriate distance when locking and unlocking due to the movement of the electronically activated piston thingy. I've had to adjust mine before with an allen head screw.
Old Oct 27, 2006 | 03:51 PM
LvN's Avatar
LvN
Default Re: HELP!!! PASSENGER DOOR WON'T LOCK!!! (GSaura)
Intact meaning nothing is loose or disconnected. I'll check it out again and see if what you're talking about needs to be tightened or greased.
milkwasabadidea
May 11, 2011 02:36 PM
renelovesnike
Apr 8, 2009 04:09 AM
DC_craze
Dec 27, 2006 05:04 PM
bboylito
Dec 9, 2004 04:52 PM
boomnn
Nov 29, 2004 10:30 AM
