Help!! Driver door wont open!!!!
When i bought my 00 ek it came with "auto lock"... but my doors only lock when i start the car. And to unlock, I would have to turn off the car.
Today, i was in a rush to get out the car, so i didn't wait long enough after i turned off my engine to let it unlock THEN open the door.
I tried almost everything to get the door to open from the inside and outside!!
Right now, the only way to open the driver door is too put the key in and turned to the right while i pull handle!!!!
I cant go another day like this, can anyone help me???
Anybody know how to fix it?
Do i need new a new door latch/wiring???
P.S. the inside door lock and unlock handles arent connected from the inside
so you touch them and they easily flap around!! (Pretty much useless)
And when I turn off the car I can hear the mechanism inside the door work but it dosent unlock!!!
Re: Help!! Driver door wont open!!!!
the auto lock is a setting on your alarm.. you should some how unlock your door and reconnect the door lock latches. depending on your alarm there is a way you set it so it locks when the keys are out and etc. so post something in the security forum for advice on that. the solenoid that locks and unlocks your car is probably loose, take off door panel and adjust it..
danmej1
Audio / Security / Video
03-20-2010 11:17 AM
