Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
lowered my front so far got some questions?? slight issuse mmm
Old Oct 27, 2006 | 03:00 PM
japspecjohn's Avatar
Default lowered my front so far got some questions?? slight issuse mmm
i just dropped the front of my si on sportlines.... didnt get to the back yet got dark to fast lol...but any ways with fast jerks of the wheel back and forth I can here the spring make noise moving metal on metal ahh well guess i should of put the top rubber thing on durrr
The instructions I was following didnt say if I needed the rubber boot cover thing so I was unaware...I should of just put it on but idk what I was thinking.... Anyways is my spring gonna fall off without it or just make annoying noises?
Old Oct 27, 2006 | 03:19 PM
Type X's Avatar
Default Re: lowered my front so far got some questions?? slight issuse mmm (japspecjohn)
its not seated correctly.
Old Oct 27, 2006 | 03:22 PM
Default Re: lowered my front so far got some questions?? slight issuse mmm (Type X)
I used the bottom rubber thing for the spring....just not that whole big one that goes from the top to the bottom(just to clarify)...idk why the hell i didnt jsut put it on
Old Oct 27, 2006 | 04:19 PM
is it necessary
Old Oct 27, 2006 | 04:35 PM
Caveman74's Avatar
You need the dust boot cover. Just twist it onto the coil. Thats the cause of the grinding
Old Oct 27, 2006 | 04:50 PM
Default Re: lowered my front so far got some questions?? slight issuse mmm (Caveman74)
is it safe to drive on for a day
Old Oct 27, 2006 | 05:06 PM
gotta goto work tomm
Old Oct 27, 2006 | 05:18 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">is it safe to drive on for a day</TD></TR></TABLE>
1. i wouldnt drive anything without all the proper parts installed
2. i wouldnt drive a car with lowering springs on half of the car
3. see one and two
Old Oct 27, 2006 | 10:00 PM
Fa1's Avatar
Fa1
Put the stock springs back on if you can't fix your current problem before driving.
Old Oct 27, 2006 | 10:29 PM
95turbodteg's Avatar
you shouldnt drive it. find a ride to work and have a friend work on it. that, or call in and fix it. stock springs arent fun to put back on unless u have a spring compressor. getting em off is easy, but putting em back on can be a little work. i havent messed with the new ones, but i know the stock springs for a crx, EK, or dc2 arent fun to put back on. take a day off and fix the problem
Old Oct 28, 2006 | 07:55 AM
Default Re: (Fa1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fa1 &raquo;</TD></TR><TR><TD CLASS="quote">Put the stock springs back on if you can't fix your current problem before driving.</TD></TR></TABLE>
why would i do that ...I just gotta put the rubber boots on...which are right here...unless you thought I threw them out
Anywho works done drove my sisters accord......gotta wrench in the rain
Old Oct 28, 2006 | 11:07 AM
Default Re: (japspecjohn)
k fronts redone...idk who said these are the easiest honda to lower....i think ef's da's ek's and eg's are by far easier atleast for the front havent got to the back yet.... iwonder how smooth it wont go lol
Old Oct 29, 2006 | 01:04 PM
I dropped a nut behind the shock tower up front so now i hear it rolling around anyone else do this...guess I need a magnet to scoop it up some how
Old Oct 29, 2006 | 01:58 PM
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">I dropped a nut behind the shock tower up front so now i hear it rolling around anyone else do this...guess I need a magnet to scoop it up some how </TD></TR></TABLE>
Does this mean you have something not attached the right way?
Old Oct 29, 2006 | 03:08 PM
Default Re: (Ross 4107)
nahhh i had the same size in the garage...just dropped one down there must of went behind the dash some where
Old Oct 29, 2006 | 06:33 PM
Fa1's Avatar
Fa1
I meant that if you can't fix the noise, then put the originals back on before you drive it.
Old Oct 31, 2006 | 02:51 PM
boostedlude97's Avatar
Default Re: (Fa1)
i did my springs in 45min by my self with a compressor and an air ratchet....lol
Old Oct 31, 2006 | 03:31 PM
Default Re: (boostedlude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedlude97 &raquo;</TD></TR><TR><TD CLASS="quote">i did my springs in 45min by my self with a compressor and an air ratchet....lol</TD></TR></TABLE>
The front was a bitch for me to push down on the hub and install the shock/spring...the back was cake....I used hand tools ... either way I prob spent 3hrs total on it
solex
Honda Civic (2001 - 2005)
28
Oct 16, 2010 05:48 PM
budget
Suspension & Brakes
Jul 8, 2006 10:50 AM
crxgator
Nov 7, 2004 07:54 PM
TexTeg
Nov 14, 2002 07:09 AM
hobo79
Feb 19, 2002 07:22 AM
