HELP!!! Weird pressure plate problem!!
Old Oct 27, 2006 | 02:18 PM
S2KBAR's Avatar
Default HELP!!! Weird pressure plate problem!!
Car : !994 del sol Vtec (b16a3 with stock tranny)
I recently took the tranny out of the car because I could not shift while the car was on. I tried shifting it while off, and it worked, so I turned the car on with my foot stuck in the clutch pedal. The car would start to go slowly, as if there was a little bit of clutch engagement, but the clutch would otherwise work normally, with the exception of not being able to shift.
Ok, after taken the tranny out, I immediately noticed that 3 or 4 of the teeth in the pressure plate were pressed towards the inside in comparisson to the rest. I said "well that must be the problem, the teeth are bent", so I countinued to dismantel the press.plate and clutch disc. After taking both out, I noticed that those 3 or 4 teeth were no longer misaligned or "pressed towards the inside", which left me puzzled.
What can I assume from this?? Has the problem fixed itself???
Your help will be greatly appreciated.
Old Oct 27, 2006 | 02:28 PM
postman's Avatar
Default Re: HELP!!! Weird pressure plate problem!! (B16 Turbo Del Sol)
i would say no and buy a new clutch kit. better for the long run
Old Nov 16, 2006 | 12:29 PM
r1de4life's Avatar
i sounds like i have the same problem right now! did u replace the pressure plate? and if so did that fix the problem?
Old Dec 18, 2006 | 09:39 PM
DVC2008's Avatar
Default Re: HELP!!! Weird pressure plate problem!! (r1de4life)
same thing happend to me found out it was the pressure plate. they gave me the wrong one.
1PT-SICK
Jan 6, 2007 01:35 AM
b18C1_liLkyLe
May 29, 2005 03:20 PM
fengxzhang
Feb 22, 2004 06:09 PM
dsolvtec
Nov 17, 2003 07:31 PM
rocco
Jul 27, 2003 11:41 PM
