96+ civic front sway bar difference
Old Oct 27, 2006 | 07:58 AM
RACEPAK's Avatar
Default 96+ civic front sway bar difference
hello everyone,
i have 97 civic hatch that didnt came with a front and rear sway bar.
i installed a rear sway bar and the car is alot stiffer in corners and it bearly leans to the sides.
now.today i got a front sway bar from a 98 4dr. and my front lca's dont have the brackets on them for it.
should i get different lca's? is it worth the trouble and money?
thanks,
Old Oct 27, 2006 | 08:26 AM
MikeD718's Avatar
Default Re: 96+ civic front sway bar difference (RACEPAK)
i put a front sway bar off a 98 ex on my 96 cx. i noticed a pretty big difference in corner handling. the front lca's arent that expensive. do it.
Old Oct 27, 2006 | 08:35 AM
viskii420's Avatar
yes... it would handle alot better in the corners.. if i was in ur position i would change the endlinks too...
Old Oct 27, 2006 | 10:21 AM
BlueIntegraBoy's Avatar
Yes, you'll notice a difference. I ran just a rear sway for a few months until I gotten ahold of a front sway.
You can use front LCAs from a 92-00 Civic EX or 94-01 Integra. To make installation easier, just swap the portion with the hole and the bushing, not the part connected to the lower balljoint of the knuckle.
Old Oct 30, 2006 | 01:40 PM
RACEPAK's Avatar
Default Re: 96+ civic front sway bar difference (BlueIntegraBoy)
thanks everyone.
i didnt had the chance looking under the car. does my chasis comes with taped holes for the bushing bolts?
Old Oct 30, 2006 | 01:57 PM
EK k kay's Avatar
Yes it comes pre-tapped with the holes for the d-brackets. I installed a 96-00 Civic EX front 22mm swaybar on my 99 hatchback and it made a difference. Yes it does induce more understeer, but you get less body roll in the corners. All you need are 96-00 Civic Ex front LCA's.
Old Oct 30, 2006 | 03:28 PM
EL Vap133's Avatar
Don't you need the Si front shock forks?
Old Oct 30, 2006 | 03:40 PM
Default Re: 96+ civic front sway bar difference (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Don't you need the Si front shock forks? </TD></TR></TABLE>
Only if upgrading to the 26mm Si/CTR front sway bar with Si/CTR front LCAs.
Old Oct 31, 2006 | 06:57 AM
RACEPAK's Avatar
cool thanks guys.
Old Oct 31, 2006 | 08:38 AM
viskii420's Avatar
dont forget.. with SI/CTR sway bar upgrade u cannot run traction bar.. w. the EX/HX/LX lca's u can run both sway bar and traction bar
my knowledge the only difference is.. that the stock EX has smaller diameter of swaybar then SI/ctr.. but u can buy aftermarket sway bar for ex/hx/lx lca's that is bigger then si/ctr sway bar
Old Nov 5, 2006 | 11:42 PM
JimDCXC's Avatar
bigger isn't always necessarily better though
Old Nov 7, 2006 | 06:22 PM
blinx9900's Avatar
Default Re: (JimDCXC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimDCXC &raquo;</TD></TR><TR><TD CLASS="quote">bigger isn't always necessarily better though</TD></TR></TABLE>
struggling with that right now, got a 96 hatch 22mm rear cant decide on front, cars used for roadracing and only runs rr slicks (nitto nto1's).. 22 or 26 that is the question...
b20hatchek
Suspension & Brakes
Oct 18, 2010 04:19 PM
bopbop93030
Apr 28, 2009 03:22 PM
Rouin
Honda Civic (2006 - 2015)
Mar 11, 2007 12:51 PM
DarkBB4
Feb 1, 2006 01:16 PM
WuRKD b16
Mar 3, 2004 02:37 PM
