Del Sol Shift Linkage/ Where to buy.
My del sol is in need of a swap. The rings are fried and i think it just ate up an alternator. I would be swapping an obd1 b18b1 into an obd1 del sol. I have all the mounts ect i need, i just need the shift linkage.
i would like to know the cheapest place to get it. I priced it out from honda ( for a del sol vtec) AND IT WAS ALMOST $300. I looked on the hasport website but they had nothing. Where can i get it the cheapest?
Re: Del Sol Shift Linkage/ Where to buy. (93eg2james)
Hasport = 125..i think
Avid Racing has em for 130 shipped it think on ebay
you can try ebay
they should be the same as EKs and EG and DC integras also
you can try ebay
Re: Del Sol Shift Linkage/ Where to buy. (bluelxfodo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluelxfodo »</TD></TR><TR><TD CLASS="quote">Hasport = 125..i think
you can try ebay
they should be the same as EKs and EG and DC integras also </TD></TR></TABLE>
not exactly. the del sol linkage has this weird little bend in it. The dc linkage wont work. And i cant use my stock ones cause the little end parts that hook up to the tranny isnt the same for a b-series motor.
you can try ebay
try ebay..they have adjustable linkages....for a little over a hundred...i personally didnt like it... wound up spending 250 at honda no other linkages worked....
Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">dam...why dont u just try ur local junk yard and look for integra shift linkage any model ?</TD></TR></TABLE>
cause if its anything like the b18c swap you can only use the shift linkage out of a del sol vtec(b16) its the only shift linkage possible besides the adjustable.. trust me i went through 2000 civic si linkage, gsr linkage sohc del sol shift linkage.. nothing works..
and i dont know about around where your from but around here good luck finding a vtec del sol in a junk yard... i couldnt anywhere within like 100 miles..
I've done your exact swap. You can ONLY use Delsol vtec (b16 delsols) shift linkages.
Good luck with a junkyard search. You could try those aftermarket companies like Hasport etc. As for me, nothing fits better than stock--strait from the dealer.
-$200 to your wallet my friend.
passwordjdm.com has em for 200, but you have to call its not listed on the site.
i had a hell of a time finding it myself. Good luck finding it cheaper then that.
you can ONLY use the stock VTEC(b16) linkage.
just got done figuring this out
i got it from the dealer for 170
not bad
fits like a charm
not bad
fits like a charm
^^^^^ like SOLvtec said. I got both bars from the dealer, $99 + $69. It took a couple days to get them in though. All the misc. hardware can be canibalized off the old linkage.
powerline707
06-16-2011 02:52 PM
powerline707
06-16-2011 01:41 PM
skiracer8148
03-17-2007 05:09 PM
SOLvtec
10-27-2006 09:30 AM
