Help with car in safe mode
Old Oct 27, 2006 | 06:31 AM
vtectuner2204's Avatar
Default Help with car in safe mode
Hello I have a 96 civic with a jdm b16a2 swap. I'm currently in safe mode(3800) P30 ecu. Ecu is fine tried a new one. Wiring is all connected but I am using a modified wiring harness with a jumper wire. I just started to see the problem after I put an MSD distributor on it. I had this problem before replaced the distributor and it went away until that distributor died and now I have the msd on it. O2 is not the problem both are reading correct values. Could injectors cause this problem? Fuel psi is normal to high. this problem happens hot or cold. will never rev past 3800 I miss vtec please help me!!!!!
Old Oct 27, 2006 | 07:22 AM
instrument's Avatar
you must be throwing a code, how bout you share which code.
Old Oct 27, 2006 | 07:36 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (instrument)
if ur car is obd2 take it somewhere to get the code checked.. otherwise check and see if ur fuel line is not pinched? or improperly installed..
Rick777
Feb 5, 2010 12:56 PM
99 4dr sohc-T
Mar 4, 2009 05:19 PM
SIR EF9
Jul 11, 2008 08:46 PM
kwizical
Jan 11, 2008 09:55 AM
CiViC SiR
Jun 25, 2003 03:59 PM
