having trouble wiring up my raybrig fogs in my ek
The connector should have a number on it (if this wire does go to the fuse box). Please provide pic and give a little better description of the wire. Is it on the engine bay harness or switch harness.
i dont have pics but i had to cut the brown connectors from the light hrness and the switch harness and wire them together cause i have a ej6 with ek front and the switch is in and wire just no power and not sure were i wire that last power wire
On the fusebox, above the fuses, there are four slots. Next to the slots are labeled with a number. Match the corresponding number on the connector to one of the slots.
The red wire should have a connector on it. Here's a pic of the fusebox. Notice the four accessory slots above the fuses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecej6 »</TD></TR><TR><TD CLASS="quote">it donr have a connector on it so i have to buy a female im guessing</TD></TR></TABLE>
Yup, buy a female connector. It will fit in the slot. I hope there was a white wire you connected to the fusebox as well.
yes and i cut it to connect to the foglight harness i had no factory plug on my harness like my boys ex did
do i have to strip the wire before i put it in the female or does not need to be striped kind of a dumb question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecej6 »</TD></TR><TR><TD CLASS="quote">ok ur the **** u owna ek i wanna see pics</TD></TR></TABLE>
I don't, but I installed my JDM fogs on my EG.
still having trouble i only have one wire left it is a red and white wire im nont sure if it goes to the battery or not
