Embarassing clutch release fork question
Well, I just dropped a new motor in the car. I'm kicking myself for not double checking this before installing the tranny, but there should be tension on the shift release fork once everything is bolted together correct?
It should be pushing towards the right/driver's side, while the slave cylinder pushes to the left to release the clutch correct?
I'm hoping that it's just the slave cylinder and that I don't have to drop the tranny again.
Thanks,
Lamar
edit:
Shouldn't the release fork rest in the direction of the white arrow when the slave cylinder is removed?
Modified by t0p_sh0tta at 7:33 PM 10/26/2006
Thanks,
Lamar
edit:
i had the same problem and turned out to be that the metal clip had come out when i put the tranny onto the block! but hopefully this did not happen to you...anyways gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">if you try moving it with your hand and there is no tension, then sorry to say but its time to rip the tranny back out..</TD></TR></TABLE>
agree
agree
No sir...
Just dropped it inspected everything and still the same issue.
Is the fork supposed to rest in the middle of the opening or should it sit to the right or left with the clutch disengaged?
I'm 99% sure that my slave cylinder **** the bed too.
edit: I'll post a vid when I can find my point & shoot camera.
edit 2: Are 92-95 and 96-00 flywheels the same? For the time being, I'm using a D15B8(CX) tranny on a D16Y7 motor.
make sure the spring that is on the inside of the release fork is sitting right on the little "nipple" on the inside of the tranny if it is, and your still not getting tension it might be that spring that is your problem..
I bled the system, and it wasn't really obvious that it was leaking. When the pedal was pressed, it would squirt directly on the ground. Upon inspection, the seal was moist, but not enough to lead me to believe that there was a leak.
blacklsvtec24
Apr 3, 2008 12:04 PM
garyhgaryh
Jul 21, 2007 03:05 PM
