B series mounts and alt in my EF...brackets missing?
When I got my engine, the rear mount on it wasn't there, and the hasport mount obviously didn't line up. The alternator mounting bracket(s) also were not there.
Wondering what I need to get to put this all together? Do I need to get that bracket from a bseries, or can I use my d-series...same question for the alternator mount(s).
Originally:
91 Honda Civic Hatch
D15B2; OBD0
Getting a:
B18 LS; OBD1
Hasport mounts
Let me know if there's any info I missed...
Originally:
D15B2; OBD0
Getting a:
B18 LS; OBD1
Hasport mounts
You need a DA rear mount bracket (t-bracket) and I just used the stock OBD1 LS alternator bracket, works fine.....
but you'll likely need to hammer your strut tower so that it installs smoothly from the top and clears the pulley
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR »</TD></TR><TR><TD CLASS="quote">Alright, check me up on this, but the lower alternator mount is mounted TO that rear motor mount, correct?</TD></TR></TABLE>
i didn't think so man.....
