piston installed on rod backwards
Old Oct 26, 2006 | 01:07 PM
d16dcoe45's Avatar
Default piston installed on rod backwards
As I was buttoning up the bottom end of my motor I noticed that I mislabeled one of the pistons--I wrote "intake" on the exhaust side and "exhaust" on the intake side--well I installed the rods onto the pistons using what I wrote on the pistons. They are Eagle rods and SRP pistons held in with spiro-locks. So I am taking the rod out to turn the whole thing around--here is the thing though--I installed the side of the rod with the bearing tang pointing towards the exhaust--just like the stock pistons are. NOw the rod and piston that was backwards--I cannot do this, if I turn the piston around, the bearing tang will be on the intake side of the piston. I know the Oem does this because the oil hole points toward the intake--but the Eagles have no such hole--I don't want to take the pistons off the rods because I am afraid I will ruin the spriro-locks and I don't have anymore and I want to get this bottom end together by tonite. Help.
Old Oct 26, 2006 | 01:28 PM
xDicktonesx's Avatar
Default Re: piston installed on rod backwards (d16dcoe45)
spin it around and re-tang your rod. thats all you can do without taking the piston off. dont reply to this just haul *** to the machine shop before they close, theyll probably tang it for 10 bucks real quick. bring cash. run forrest, run.
Old Oct 26, 2006 | 02:05 PM
d16dcoe45's Avatar
Default Re: piston installed on rod backwards (xDEFTONESx)
thanks--but I CAREFULLY took out the sprio-lock without hurting it, turned piston around, and put it back. It used to take me, I kid you not--45 minutes to install each spiro-lock and I would bend and mangle it--I realised I was fighting it and now I can put them in in like 30 seconds. But, what would have happened if I installed it with the tang on the "wrong" side?
Old Oct 26, 2006 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">thanks--but I CAREFULLY took out the sprio-lock without hurting it, turned piston around, and put it back. It used to take me, I kid you not--45 minutes to install each spiro-lock and I would bend and mangle it--I realised I was fighting it and now I can put them in in like 30 seconds. But, what would have happened if I installed it with the tang on the "wrong" side?</TD></TR></TABLE>
nothing. you could have mirrored the tang, put the hold thing in backwards and been fine. rods dont give a **** which way they spin, but bearings do.
Steeve_Civic
May 28, 2012 10:37 AM
Rootie524
Jul 4, 2011 01:26 PM
Yuleluder
Feb 15, 2006 05:14 AM
jakscivic
Jan 13, 2006 02:48 PM
CRX Lee
Feb 9, 2004 08:39 AM
