replaced front rotors+pads, noise from rear drums!?
Old Oct 25, 2006 | 11:07 PM
SoullessJapaneseMachine's Avatar
Default replaced front rotors+pads, noise from rear drums!?
1997 Civic EX
front has rotors, rear has drums
just replaced the front rotors and pads with all new ones from autozone.
after i took the car for a spin, i notice a moan/sqeal noise only when letting go of brake pedal. i opened the windows, and it looks like the sound is coming from the rear brakes.
does not make any noise when engine is off...
its more audible on the outside of the car...
note: i didnt have to compress the piston in the caliper at all during the process.
stopping power is good (normal).
brake fluid level was slightly above max before i started, and i didnt open it again, and no leaks
anyone come across something similar??
Old Oct 26, 2006 | 05:03 AM
De_tour's Avatar
Default Re: replaced front rotors+pads, noise from rear drums!? (SoullessJapaneseMachine)
I get this as well with having drums.
might just be really dusty or needs ajustment.
disc conversion keeps this from happening
Old Oct 26, 2006 | 05:29 AM
Sloshy's Avatar
sound like the release spring for the drums are giving out. 2 way to fix rear disc conversion or spend close 80 on litlle springs to rebuild the drums
Old Oct 26, 2006 | 08:10 PM
Default Re: (hatch-E-vanish)
update: also does it when RELEASING e-brake
as far as the conversion goes... would i need to buy/order any NEW parts? or can everything needed be pulled off a donor car?
redcivic44
Feb 18, 2008 01:08 PM
dudeomega2000
Apr 26, 2007 09:28 AM
user 6297290
Feb 23, 2006 05:34 AM
redwinqs
Nov 9, 2003 05:08 PM
RTW DC2R
Mar 3, 2003 10:55 AM
