Brakes are squealing badly!
Old Oct 25, 2006 | 07:06 PM
rufridn's Avatar
Default Brakes are squealing badly!
My front brakes on my integra have been squealing recently. i have sprayed them with water to remove all the brake dust but they still squeal. I checked the thickness of the pads and they are a little less than 1/4 inch thick, both outer and inner. They are PBR/Axxis metal masters. Are they bad pads or what?
Thanks
Old Oct 26, 2006 | 03:07 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: Brakes are squealing badly! (rufridn)
Water??? You should use brake cleaner. Take the pads off and put some brake squeal lube on them and check the calipers and make sure there are no foreign objects(rocks..etc) wedged in anywhere. If that doesn't work get some new pads and have the rotors turned.
Old Oct 26, 2006 | 08:19 AM
rufridn's Avatar
Default Re: Brakes are squealing badly! (attentionwhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by attentionwhore &raquo;</TD></TR><TR><TD CLASS="quote">Water??? You should use brake cleaner. Take the pads off and put some brake squeal lube on them and check the calipers and make sure there are no foreign objects(rocks..etc) wedged in anywhere. If that doesn't work get some new pads and have the rotors turned.</TD></TR></TABLE>
ok will do. thanks
Old Oct 29, 2006 | 07:49 PM
s2k24's Avatar
it sounds like you need to get new brake pads and have the rotors resurfaced so you have nice new surfaces against one another. if you want to try to last a little longer on your old pads you should sand the glaze off of the pads if there glazed
Old Oct 30, 2006 | 01:59 PM
Bense's Avatar
indicators hitting rotor.
zakarylakota
Dec 30, 2018 06:12 PM
turnsignalandy
Nov 12, 2006 03:35 AM
crx00
Apr 4, 2006 08:38 PM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
SL!M
13
Jun 23, 2003 03:59 PM
