Brake Pads. WAY TOOO HOT!!
When i did my suspension work in the front , I decided to put some new brake pads in, and on the left passenger side brake, it gets extremely hot, and sometimes stinks. they were 30 bucks and there semi-metallics. What is causing the one side to overheat and not the other. I mean really hot to, the rim starts to get really hot. can anyone help me?
had that happen to a car i used to have....depending on the pads...its probably just the break in on the pads...mine were brembo rotors and pads and the rotors were turning black...took about 2 weeks of breaking and lots of spraying the dust off with cleaner or water to make it go away...good luck
1 Post
Re: (freezing-acid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freezing-acid »</TD></TR><TR><TD CLASS="quote">is your parking break on ?
haha
j/k
Actually it probably is the parking break. Take the armrest out and readjust it using the 10mm nut. loosen it up a bit.
haha
j/k
My rim is getting hot also. I hear a squeeking noice from my rear as I break and even when I am driving. I think it may be a clip. My caliper was seized, but I changed that.
New pad, new rotors, new caliper, and I still getting that sound. It also appears that the pad is not making full contact with the rotor. You can see the contact area on the rotor and there is a good CM from the inner begining that is dirty... Thus, no contact. I am going to try the e-brake thing.
apexinghonda
45
05-27-2004 07:02 PM
