Leaky axle seals
Old Oct 25, 2006 | 05:01 PM
EG2Driver's Avatar
Default Leaky axle seals
I just replaced my clutch and while removing the axles, i torn the driver side. I went to the dealer and got a new one. Put it on. Now it leaks, and so does the passenger one, which did not leak before. The passenger axle was taken out straight and didnt damage the seal.
I am using GM syncromesh, which is synthetic i think? Could that cause it to leak because the molecules are smaller or something? Im kinda bummed out because this is liquid gold and it costs so damn much....I dont want it to leak!
What do you guys think it is? Is it normal for some leaking to occur at first or what?
Old Oct 25, 2006 | 05:17 PM
IslandStyle's Avatar
Default Re: Leaky axle seals (DeadEnd9009)
Starting with the obvious but sometimes overlooked, did you make sure the dealer gave you a new seal with the new axle? Also, when you drained the fluid to replace the axles, did you properly torque the bolt back in... or overtighten it?... or did you re-use a crush washer (which you cannot do)?
Old Oct 25, 2006 | 05:26 PM
EG2Driver's Avatar
Default Re: Leaky axle seals (IslandStyle)
crush washer is new.....seal was identical to the one i had on there before (put them side by side to ensure)
Thanks for the help i'll go make sure the seal is seated properly i guess....no idea why the passenger side is leaking tho.
Old Oct 25, 2006 | 05:42 PM
Heylookits shawn's Avatar
when i changed my axle seals, i pushed the drivers side one in too far, and the diff chewed the inside up, causing it to leak.
SlvrJdm
Oct 28, 2012 06:24 PM
driveslow
19
Mar 5, 2009 07:03 PM
ILLICON3000
Dec 20, 2004 12:50 PM
ABK
Apr 8, 2004 08:48 AM
PyroVTEC
Aug 25, 2002 12:05 AM
