lsvtec vtec wire wiring harness question for my ek civic hatch
Old Oct 25, 2006 | 05:00 PM
SrT4u2nV's Avatar
Default lsvtec vtec wire wiring harness question for my ek civic hatch
hi all. i've searched and searched and i know i found this somewhere on tyhe net before and i thought i got all the right parts, but i went to hook some things up today and it didn't seems right. anyone with any input on if this works or what i need to make it work, i greatly appreciate it. thanks!
i have a 96 dx hatch, and an odb1 lsvtec motor. i currently have obd1 injectors, obd1 alternater, obd1 p28 ecu, obd1>obd2 ecu conversion harness, odb1 distributer, and a 96-98 obd2 ex wire harness.
please help
THANKS ALWAYS HT !
Old Oct 26, 2006 | 07:35 AM
SrT4u2nV's Avatar
Default Re: lsvtec vtec wire wiring harness question for my ek civic hatch (SrT4u2nV)
bump, i also have an ls obd1 wire harenss if i need to combine the 2 or something
Old Oct 26, 2006 | 12:05 PM
HondaPartsHero's Avatar
Technical Hero
You'll need wiring for the following:
1. IACV plug conversion from 3 wire to 2 wire
2. OBD1 injector plugs to swap over to your harness to use the obd1 injectors
3. You may have to do this to your alternator
4. You'll also have to swap over the distributor plugs from your car to the one on the OBD1 distributor
5. There will be a plug near the crank shaft that is the crank position you just tie this up somewhere
Old Oct 26, 2006 | 10:32 PM
WhiteNess's Avatar
Default Re: lsvtec vtec wire wiring harness question for my ek civic hatch (HondaPartsHero)
gonna need to do all that and get an obd2a-obd1 jumper harness for that p28
Old Nov 1, 2006 | 11:12 PM
MariakRSX's Avatar
New User
bump
Old Nov 11, 2006 | 02:01 PM
SrT4u2nV's Avatar
ok, i swapped all the parts right and my car doesn't start... but i think it's cause the shell i got had an alarm in it before and interior wires are messed up. if anyone has a pic of stock wires under the dash, please lmk
ggallinstyle
Jun 25, 2013 12:10 PM
my1992cb7accord
Dec 15, 2011 09:47 PM
twistedimage
May 22, 2010 10:56 AM
HarosGSRek
Engine Management and Tuning
13
Jun 30, 2009 06:42 PM
v8 integra
Feb 21, 2006 08:04 PM
