4th cylinder not firing
Old Oct 25, 2006 | 02:56 PM
crawfo661's Avatar
Default 4th cylinder not firing
what would make only 4th cylinder on a d16 not fire, any help or suggestions appriciated
Old Oct 25, 2006 | 03:07 PM
ExedyHF02
Guest
Posts: n/a
Default Re: 4th cylinder not firing (crawfo661)
i had that same problem before my swap...usually your engines piston is gone or something like that...its stupid...how old is your car?
Old Oct 25, 2006 | 03:19 PM
crawfo661's Avatar
Default Re: 4th cylinder not firing (ExedyHF02)
it has good compression in all cylinders though, it is a jdm sohc zc with like 10k on it
Old Oct 25, 2006 | 03:36 PM
crawfo661's Avatar
bump, i really need help here guys, i can't for the life of me figure this one out
Old Oct 25, 2006 | 04:10 PM
haroldthefly91crx's Avatar
is it getting spark?
and check spark plug condition
Old Oct 25, 2006 | 04:43 PM
Tippyman's Avatar
Default Re: 4th cylinder not firing (haroldthefly91crx)
Change plugs, plug wires, dizzy rotor and cap.
It's a regualr maintanance thing that could be your problem.
Ever broken a T-belt? Could be bent or broken valves.
Old Oct 25, 2006 | 04:46 PM
Coltmorris's Avatar
Default Re: 4th cylinder not firing (Tippyman)
check your injectors--start it up and put a screwdriver on it..and your ear to the handle you should hear a ticking ..might be a bad injector!
Old Oct 25, 2006 | 05:49 PM
sleepermachanic 8's Avatar
Sounds like a spark issue. When I helped a friend do a swap ( little different but same idea) we had some bad wires leading to the dizzy. Continuity test all wires to be sure they are all getting a good connection.
Old Oct 25, 2006 | 06:52 PM
ic's Avatar
ic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Ever broken a T-belt? Could be bent or broken valves.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawfo661 &raquo;</TD></TR><TR><TD CLASS="quote">it has good compression in all cylinders</TD></TR></TABLE>
check spark (cap, rotor, wires, plugs)
check fuel injector on that cylinder (stethescope, listen for clicking of pintle)
Old Oct 26, 2006 | 01:06 AM
crawfo661's Avatar
Default Re: 4th cylinder not firing (ic)
never broken a timming belt, the plugs and wires are new, and the internalls on the dizzy look new however i did try a known working dizzy and that didn't help, i am also throwing codes 7, 10 and 16. i was told these are for throttle position sensor, air intake temperature sensor, and bad fuel injector. However i checked and all the injectors are working, I bought this car from some coke-head idiot and he had no idea what he was doing, he put the zc in it and did a dpfi to a mpfi harness job and did it terribly wrong. when i bought the car i took off the head and did a mini me swap and i also put in another converted dpfi harness that i knew was propperly converted no that everything is gettin back togather it still is not right, any ideas on what else it could be?
Old Oct 26, 2006 | 04:09 AM
89 civic si's Avatar
sounds like alot of mess i would check the injectors...as stated before. how can you verify the motor only has 10k on it?that coke head could be bullshiting you
Old Oct 26, 2006 | 10:08 AM
crawfo661's Avatar
Default Re: 4th cylinder not firing (89 civic si)
the coke heads dad told me, hes the one who actually bought the zc in june for the kid to do it, he had papers that gauranted true jdm and under 20k or some bullshit like that, he said he was told buy the salesman it had 10K, but i don't trust anyone, especially in my area, but whatever, motor is good i just gotta find the glich
Old Oct 26, 2006 | 07:01 PM
crawfo661's Avatar
bump for sum help here guys, i got all day tomorrow to work i just need ideas
Old Oct 27, 2006 | 04:57 AM
ExedyHF02
Guest
Posts: n/a
pistons, that was the problem in my d15 engine...dunno though
Old Oct 27, 2006 | 09:28 AM
crawfo661's Avatar
it wouldn't have good compression then though
Old Oct 27, 2006 | 09:37 AM
Super Chicken's Avatar
Seriously, check your fuel injector on #4 swap it for a know good one (like switch #1 with #4) and see if the other cylinder drops out. I have seen injectors making the sound, but not working before and the only way to check is either pull it off and apply low voltage while blowing 40-50psi ait through it or just swap one with another.
I once had an 89 Integra that someone had put coca-cola in the gas tank and the sugar would slowly clog one injector and then another every time you would start the car, after the car would warm up and cool back down a different injector would clog up!
If you have a "noid" (an electronic tool to check for voltage at the injector clip) use that first. If the wiring is Fubar all else is a waste of time
Old Oct 27, 2006 | 03:59 PM
1990si's Avatar
Default Re: 4th cylinder not firing (Super Chicken)
bump cause this kid needs his car running.
Old Oct 27, 2006 | 10:08 PM
crawfo661's Avatar
Default Re: 4th cylinder not firing (1990si)
we did swap around injectors and it was always the same cylinder, i got a couple extra, i'll toss those in in the morning to give it a shot, come on guys show sum love for a guy who goes to school, has a job and is tryin to pimp an old school ef
Old Oct 27, 2006 | 10:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawfo661 &raquo;</TD></TR><TR><TD CLASS="quote">we did swap around injectors and it was always the same cylinder, i got a couple extra, i'll toss those in in the morning to give it a shot, come on guys show sum love for a guy who goes to school, has a job and is tryin to pimp an old school ef </TD></TR></TABLE>
Check the wiring! You need to be sure that you're getting the correct voltage across the injector. You should have ~3v on the wire coming from your resistor and then the ground signal from your ECU buy a noid for $5 at Yo Yo Auto (or your fav parts store) and plug that in to the injector clip.
Often times when doing MPFI swaps the wiring gets just a little tweaked and this causes easily overlooked problems
Old Oct 28, 2006 | 12:48 AM
UKjeff's Avatar
Sorry this might not be quite relavent, however I experienced similiar problems and had a code 7, TPS.
Car was running on 3 untill I replaced the dizzy which cured it.
Might be worth a shot?
SiBuddy00
16
Sep 10, 2015 01:59 AM
Nine0DA7
Mar 25, 2009 07:23 PM
EL TYPE R
Jan 30, 2009 04:19 PM
unrealgtx
Aug 4, 2007 12:42 AM
nY's FiNeSt
11
Apr 12, 2004 01:28 AM
