Crx won't start
6 days ago, it starts up fine. I went out of town for work and arrived back today and I tried to start it up but it won't start.
I'm getting a code 9. What is wrong? It's getting battery power. Just won't turn over. Help please.
Where is the Tensioner? I took out the cover for the cams and I can't seem to locate where the tensioner is at. Or maybe i'm just confusing it with another item. Pictures would help. Thanks.
It looks like a polished pulley. Almost to the center of the block. (Does not look like a gear) the tensioner fastens you timing belt. When you loosen that, the timing belt get loose. Then aliegn the the cam gears and crank pulley. 1st piston should be all the way up. To see this, take sparkplug out from the one closset to cam gears. Stick screw driver in port, you should feel the piston right away, I think you can also see it too. If the screw driver goes way to much into the port then piston is not aliegned. Hit me up at cyboe226@yahoo.com if any more questions.
esmzoso
Jul 17, 2011 12:34 PM
gaydm.accord
Apr 16, 2005 07:03 PM
h46it
May 17, 2003 08:26 PM
