Rear Power Window Drama...Help!!!
Ok...here are the specs
94 Honda Del Sol - 1.5 D15 non vtec
Power windows - driver, passenger, and rear
Heres the problem - I purchased this car nearly two years, and the rear power window has never worked. Initially i assumed that the problem was the window motor, so i left it be for the last 2 years and just recently bought a new motor for it. I replaced the motor, plugged everything in, and it still does not work. so far i have:
replaced the motor
replaced, and checked all under dash fuses
replaced and checked all under hood fuses
the only other problem I can assume is that either the replacement motor i purchased is not functional as well, or that maybe there is some problem with the harness. Any other ideas you have are greatly appreciated. The window is now in a lowered position so im afraid to leave it overnight if i dont have to, but i cant figured what else the problem could be, so please help!
thanks in advance
replaced the motor
thanks in advance
1. it could be that the window actuators you bought are faulty.
2. maybe there is an issue with your harness not getting power to the actuator: you can solve this by having someone check it who is an experienced electrician or a weekend warrior.
you can always manually check the motor. hook power up to one side and ground the other and see if it does anything(or reverse them, powering one side makes it go up and powering the other side will make it go down).
colinIG
10
Apr 24, 2013 12:31 AM
jdmferiodrvr
Feb 23, 2009 08:32 PM
1FSTGSR
Aug 2, 2002 09:09 PM
