Power Windows will not go up. HELP!!!
I have a '93 Del Sol Si. The passenger side and back window will not go up. Has anyone ever had this happen? Can anyone help? What fuse is for the windows?
1 Post
Re: Power Windows will not go up. HELP!!! (1FSTGSR)
does your driver side go up? maybe is just the lock on your door(driver side), that locks the passenger window. Its happened to me that I thought something happened, but it was just that lock
Re: Power Windows will not go up. HELP!!! (eg_nezay)
if the motor or fuse for them isnt dead you might try some silicone spray in all the corners of the window.... mine were starting to stick and i went to honda they told me it was a common problem and to just go buy a can of lube.... worked great... also helped my squeaky roof problem.... now all i need to do is fix the leaky seal problem...
colinIG
10
04-24-2013 12:31 AM
