Temp guage problem
does it drop to the bottom or just a little, when the engine revs the flow of coolant is faster in return cooler may be normal if it drops all the way change the single wire coolant temp sensor located next to the thermostat housing with a OEM sensor aftermarket sensors are not reliable and cost is not much different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nah22accord »</TD></TR><TR><TD CLASS="quote">Goes all the way down to C. It seems to only to it when the rpms are high. </TD></TR></TABLE>
That's a rapid drop. No way will coolant chill that much that quickly. I would look for a poor wiring connection or connector.
HatchedGTI
Oct 4, 2008 12:28 PM
allmotor.net
Apr 24, 2003 02:58 AM
