need some info on spoon jdm itr pistons
Old Oct 25, 2006 | 09:49 AM
01-0720's Avatar
Default need some info on spoon jdm itr pistons
ok im looking at buying this guys jdm itr block, the guys says it was bored and honed to 81.5mm
and iv got a good friend thats got a set of spoon jdm itr pistons, that he will sell me for cheap
so i was wondering what size are the spoon pistons, like will they fit in this guys block that was honed and bored
thanks
also what kinda comp ratio will these pistons put me at, i was thinking of using a spoon headgasket also
Old Oct 25, 2006 | 09:53 AM
RagingAngel's Avatar
Default Re: need some info on spoon jdm itr pistons (01-0720)
Spoon OS pistons IIRC only go up to 81.25.
You'll have to get some aftermarket alternatives like from RS Machines or something.
http://www.zealautowerks.com/index.html
try that for compression.
Old Oct 25, 2006 | 10:08 AM
YumVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">also what kinda comp ratio will these pistons put me at, i was thinking of using a spoon headgasket also</TD></TR></TABLE>
spoon pistons are just regular JDM ITR pistons that have been "balanced". on stock ITR rods in a b18c block with b18c crank you will have a compession ratio of 11:1.
Old Oct 25, 2006 | 10:24 AM
BlueR's Avatar
Default Re: need some info on spoon jdm itr pistons (YumVTEC)
the "balancing" is done by weighing hundreds of jdm itr pistons and grouping them into sets of 4 with the most equal weights
Old Oct 25, 2006 | 10:40 AM
tartje's Avatar
Default Re: need some info on spoon jdm itr pistons (BlueR)
and how much do they charge for this honour?
Old Oct 25, 2006 | 11:13 AM
01-0720's Avatar
Default Re: need some info on spoon jdm itr pistons (tartje)
thanks for the info guys
even though this way whould be alot less expensive, i think im gonna stick with my original idea and keep my block and build my motor, gonna go with oversized oem ctr pistons, and skunk2 pro2's etc etc
thanks again
Old Oct 25, 2006 | 11:42 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">gonna go with oversized oem ctr pistons, and skunk2 pro2's etc etc
Do not run CTR pistons. You will make more power with P30 pistons, even though they are less compression. PCT pistons (CTR) have a horrible dome design that hinders flame travel and combustion efficiency, plus you will have a very hard time with clearances with Pro2's and PCT's.
My $.02
Old Oct 25, 2006 | 03:11 PM
01-0720's Avatar
Default Re: need some info on spoon jdm itr pistons (92TypeR)
again some excellent information, thanks alot
can i still get new oversized oem p30's?
Old Oct 25, 2006 | 03:39 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">again some excellent information, thanks alot
can i still get new oversized oem p30's?</TD></TR></TABLE>
Yes.
We've built a few mild 1.8's with P30's and Blox B with simple bolt-ons, all of them have broke 200whp.
Old Oct 25, 2006 | 03:55 PM
01-0720's Avatar
excellent that gives me hope
thanks again
Old Oct 25, 2006 | 06:05 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">ok im looking at buying this guys jdm itr block, the guys says it was bored and honed to 81.5mm
thanks
you have 5000 plus posts and you are asking stupid questions like this??? have you not read a thing in this forum??
Old Oct 25, 2006 | 06:11 PM
01-0720's Avatar
Default Re: need some info on spoon jdm itr pistons (chad)
sorry i dont memorize piston sizes
Old Oct 25, 2006 | 06:22 PM
it's not about memorizing....Chad was getting at that little red link at the top right corner....
OLM-02R
15
Jan 25, 2005 07:51 PM
ar2d2
Oct 23, 2004 09:40 AM
PYITR821
Jun 9, 2004 11:30 PM
guyuenvy
Mar 11, 2002 06:17 PM
AutoXsi2000
Jan 14, 2002 11:16 AM
