Thinkin of doin all motor on a b18c5 (type R UDSM)
Old Oct 25, 2006 | 09:01 AM
ek9tl's Avatar
Default Thinkin of doin all motor on a b18c5 (type R UDSM)
ok guys im throwing out blue smoke so im goin into the block to change the pistons to higher compression. Anyting else i shudd do since i got the block open. Im tryin to go fast..thanx
Old Oct 25, 2006 | 09:17 AM
dinko's Avatar
Default Re: Thinkin of doin all motor on a b18c5 (ek9tl)
there's a few stock bottom end b18c5's with bigger cams makin close to 200whp.
look into porting the head with a better header and air intake setup if u wanna go "fast"
Old Oct 25, 2006 | 09:28 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9tl &raquo;</TD></TR><TR><TD CLASS="quote">ok guys im throwing out blue smoke so im goin into the block to change the pistons to higher compression. Anyting else i shudd do since i got the block open. Im tryin to go fast..thanx</TD></TR></TABLE>
Since its smoking: new rings, new valve seals (in the head)
For compression: pistons I'd go for JDM ITRs/P30s or something aftermarket to raise it up even more. And you can even get the head milled a little
Old Oct 25, 2006 | 09:42 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: Thinkin of doin all motor on a b18c5 (SkoundrelUSA)
yea! What he said ^^^^^^
RACEPAK
May 24, 2008 11:03 PM
EJ1_203
10
Sep 28, 2007 04:28 PM
dek1mfk
Jun 22, 2007 10:47 AM
omgwtfhaxnub
May 16, 2005 01:17 PM
BeavisB16
Feb 22, 2003 12:28 PM
