car is smoking do to high fuel pres what can i do to get it to stop?
Old Oct 25, 2006 | 03:55 AM
d_a_b's Avatar
Default car is smoking do to high fuel pres what can i do to get it to stop?
i have replaced every thing and i am still getting to much fuel to the motor.
and it is making it smoke. the motor is a b18 out of a 93 teg. the motor was rebuilt
it has less then 200 miles on it. i dropped it in my Del sol i used the ecu from the
teg i got the motor out of and i have tried changing the ecu and still to much fuel
it is not popping up no cells,it ideals bad when its cold but when it worms up it ideals better and less smoke and its not oil smoke. i changed the plug yesterday
and they have allot of black carbon buildup on them.
........... can any one help and tell what i can do.............
Old Oct 25, 2006 | 05:43 AM
instructor74's Avatar
Default Re: car is smoking do to high fuel pres what can i do to get it to stop? (d_a_b)
Have you checked to see what the fuel pressure is? If that is okay I would check the wiring to the injectors make sure it is correct. If that is okay then you might have a stuck open injectors. Do you know if the injectors are the stock ones or have they been changed for higher flowing ones?
Old Oct 25, 2006 | 09:10 AM
d_a_b's Avatar
Default Re: car is smoking do to high fuel pres what can i do to get it to stop? (instructor74)
it has stock injectors i had a shop check the fuel pressure and they said it was to hi.i had the injectors checked also and they are good. also put on a new fuel pressure regulator still getting to much gas but it seams to run and idle good when it's wormed up but cold it runs like sh-t
Old Oct 25, 2006 | 09:12 AM
Rev2Eight's Avatar
bump i may have the same problem but it runs fine when cold.
Old Oct 25, 2006 | 10:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d_a_b &raquo;</TD></TR><TR><TD CLASS="quote">it has stock injectors i had a shop check the fuel pressure and they said it was to hi.i had the injectors checked also and they are good. also put on a new fuel pressure regulator still getting to much gas but it seams to run and idle good when it's wormed up but cold it runs like sh-t</TD></TR></TABLE>
You could try an adjustable fuel pressure regulator to bring it back down to stock level. Do you know the history of the car?How many owners before you and any mods that were done? What fuel pump is in the car. some people change them out for higher flow pumps.
Old Oct 25, 2006 | 12:00 PM
d_a_b's Avatar
i just got the car so don't know much about it. dono about the fuel pump
what kind of adjustable fuel pressure regulator can i use??
Old Oct 25, 2006 | 06:04 PM
d_a_b's Avatar
ttt
Old Oct 26, 2006 | 05:04 AM
just get the stock fuel pump for that car and make sure that there is not a secondary fuel pump on the car. Start at the gas tank and follow the fuel lines to the fuel rail.
Old Oct 26, 2006 | 01:01 PM
d_a_b's Avatar
thanks i'll try that
B_Swapped93
Mar 25, 2013 08:02 PM
rlembitz
Dec 24, 2010 09:04 AM
feriotypeR
Engine Management and Tuning
10
Dec 16, 2009 09:31 AM
d_a_b
Oct 26, 2006 01:02 PM
evilone
Oct 8, 2004 08:30 AM
