How do you remove Acuraca center caps?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Flathead? If not, remove the wheel and pop it out from the back.</TD></TR></TABLE>
I can't believe you even made a thread on this..
Common sense FTW!!!1
A flat head should work fine. I used a flat head to get the center caps off a TL because they had theft safety lugs on each rim. but if you take the rims off they should punch out.
so putting it back in i can just insert them front the front? and they'll pop in right?! >< sorry for asking i just dont want to break or ruin anything T_T even tho it's common sense :S *jumps out a window*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate047 »</TD></TR><TR><TD CLASS="quote">WTF is Acuraca?
i tried to correct it but it only corrected the inside T_T, *slaps*
</TD></TR></TABLE>i tried to correct it but it only corrected the inside T_T, *slaps*
J.nguyen
Jun 23, 2006 01:00 PM
JDM_Type-R
Oct 5, 2002 11:09 AM
