Automatic Seat Belt Stuck forward - won't move back
Old Oct 24, 2006 | 05:31 PM
gatorfish's Avatar
Default Automatic Seat Belt Stuck forward - won't move back
Any ideas on why the automatic seat belt on my 1990 accord won't move back when I close the door?
It was working recently until I replaced the door latch. I replaced the latch with an '02 accord latch (because it was all I could find) and the '02 latch didn't have electrical for the belt. The latch was awful to replace but works well. Now, the automatic seat belt remains forward. I tried to see if I could connect the old latch and close the door and "trick" the seatbelt into going back, but it didn't work. I really don't care if the automation works anymore, but would love to get it back in its locked position.
Any thoughts would be appreciated.
Old Oct 25, 2006 | 02:20 AM
AccordEX1991's Avatar
Default Re: Automatic Seat Belt Stuck forward - won't move back (gatorfish)
Crank it manually to closed position then remove the seatbelt motor fuse in the engine compartment fuse box.
While the door center pillar trim is out, check the limit switches.
Old Oct 25, 2006 | 06:34 AM
TheMuffinMan's Avatar
He knows where you live!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">'02 latch didn't have electrical for the belt. </TD></TR></TABLE>
Ok am I crazy or did you just solve your problem right there, why not either find a 90 latch or I would suggest taking it to Honda as they have a lifetime guarentee on your seat belts.
Old Oct 29, 2006 | 08:00 PM
88YellowRexSi's Avatar
Default Re: Automatic Seat Belt Stuck forward - won't move back (AccordEX1991)
So now suddenly im havin the same probs with mine... Im new with accords... How do you crank it manually? All that happens with mine is of course it is stuck forward, and when I open the door the light in the cluster flashes and that annoying beeping starts going off... checked fuses and they are all good.. the passenger side seems to work but its kinda slow.. think it may be the latch? any ideas?
Old Nov 17, 2010 | 06:27 AM
Jud-Boosts's Avatar
Im havin the same prob w/ my ef sedan, anyone figure it out yet?
Villani77
Nov 17, 2018 08:47 PM
george34
Aug 10, 2008 02:41 AM
Susie67
May 4, 2006 11:27 PM
jdm_lover
Jul 11, 2004 01:28 AM
TnVol
Sep 17, 2002 02:47 PM
