Hub and Quick Release Installation
Old Oct 24, 2006 | 04:16 PM
SilverEkHatch15's Avatar
Default Hub and Quick Release Installation
Searched like crazy and found a couple different threads from other sites of how to install the hub and quick release and I think i know how to do it but I have also seen many having problems with the install with alignment and horn an such. So i guess Im wondering if I should go to a local speed shop and have them assist me or if I should just go for it and see what happens.
Old Oct 24, 2006 | 04:26 PM
dorifto_83's Avatar
Default Re: Hub and Quick Release Installation (SilverEkHatch15)
It's not hard to do, and even if you mess up you can do it over again. I should be installing mine soon, so I'll post a guide once I do.
Old Oct 24, 2006 | 04:53 PM
Yea, Im just a little hesitant to get it going. I dont wanna have to take it to get realigned because I just got it done you know. Theres a great write-up on JDMC but its for an S2K and there are no pictures, I figured it would be about the same though. That would be great if you could post that up. Thanks guys
Old Oct 24, 2006 | 05:50 PM
2coupes's Avatar
there you go, even tells you how to keep cruise control
http://importnut.net/civicsteeringswap.htm
it doesn't show the quick release, but it's just 6 allen bolts on to the hub, then 6 allen bolts to put the other part of the QR on to the wheel
i did this a couple months ago and it was alot easier than I thought, just do it yourself man
and a pic to get you motivated
Old Oct 24, 2006 | 06:11 PM
Default Re: (2coupes)
Hey thanks a lot man, that's exactly what I've been looking for. So your experience overall wasn't too bad? Thanks again guys
Old Oct 24, 2006 | 06:13 PM
2coupes's Avatar
it wasn't bad at all, probably took about 45 minutes or less
Old Oct 24, 2006 | 06:16 PM
dorifto_83's Avatar
you can't throw off the alignment, if your steering wheel isn't straight it could be fixed. Alignment stays the same
Old Oct 24, 2006 | 06:19 PM
Default Re: (dorifto_83)
Alright thats good to hear. Im pumped now. Thanks again for the diagram and the info.
Old Oct 24, 2006 | 06:39 PM
Harryflores's Avatar
Default Re: (SilverEkHatch15)
yeah, to do it is not that hard !! That was a really helpful link !
Old Oct 24, 2006 | 07:04 PM
Default Re: (Harryflores)
Oh one more quick question. I've read that I'm supposed to disconnect the battery lines to prevent that bag blowing up in my face. True?
Old Oct 24, 2006 | 07:19 PM
2coupes's Avatar
yep
Old Oct 24, 2006 | 07:32 PM
Ok, I think I'll tackle it tomorrow. Thanks to all for the info again.
Old Oct 24, 2006 | 08:57 PM
I just got my NRG QR today and when i press down on the button for the release nothing budges. Does there have to be a steering wheel engaged in the QR for it to release. I feel like a total idiot but I was just wondering. Thanks and sorry for the stupidity.
Old Oct 24, 2006 | 09:07 PM
Fatchance187's Avatar
Make sure you wait 5-10 minutes to let the power drain after you disconnect the battery...some people forget about that
Old Oct 24, 2006 | 09:43 PM
2coupes's Avatar
Default Re: (Fatchance187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatchance187 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you wait 5-10 minutes to let the power drain after you disconnect the battery...some people forget about that</TD></TR></TABLE>
it was mentioned in the link
"You may want to disconnect the battery and wait about 15-30 minutes before you start this process. You risk having the airbag deploy and cause serious injury if you don't disconnect the battery."
Old Oct 25, 2006 | 05:30 AM
Syndacate's Avatar
Hey just a Q..
Do they center align an aftermarket steering wheel the same way they center align a stock steering wheel?
(they being an alignment shop)
Old Oct 25, 2006 | 09:46 AM
Default Re: (Syndacate)
So is the QR supposed to release right out of the box? Or does it need to be installed and all that to do it?
Old Oct 25, 2006 | 11:28 AM
bump
Old Oct 25, 2006 | 11:34 AM
2coupes's Avatar
it will release out of the box, but it's tighter since it hasn't been "released" before, plus it's hard to do with only 2 hands when it's not on the steering column
Old Oct 25, 2006 | 11:38 AM
So when i attach to the hub and have the wheel in it will release easier? Because I cant do it now and dont want to get it all installed and have it not work. Thanks a lot i appreciate all the info.
Old Nov 1, 2006 | 02:57 PM
spoonhatchblack's Avatar
Ph0t0bug
Dec 30, 2015 09:26 PM
cvc1393
Sep 15, 2009 09:32 PM
sik_tC
Audio / Security / Video
Sep 16, 2008 11:43 AM
thaimonkey
17
Dec 20, 2005 06:48 AM
