Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How to remove ECU?
Old Oct 24, 2006 | 04:13 PM
NA4sho's Avatar
Default How to remove ECU?
Can someone plz put up a pic of the ECU for the SI cuz i wanna send it in for a reflash...just wanna make sure i can remove it properly...thank u guys
Old Oct 24, 2006 | 06:22 PM
eL's Avatar
eL
Do you atleast know it's under the hood?
Old Oct 24, 2006 | 06:52 PM
Nohawk's Avatar
Default Re: How to remove ECU? (NA4sho)
Per Hondata website:
The ECU is located under a plastic cover to the right of the battery under the hood. You will need a 10mm socket. This is what it looks like - in place and removed from the car.
http://www.hondata.com/reflash_06_civicsi.html
Old Oct 24, 2006 | 08:27 PM
NA4sho's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Do you atleast know it's under the hood?</TD></TR></TABLE>
found it...
Modified by NA4sho at 6:38 PM 10/26/2006
Old Oct 29, 2006 | 07:21 PM
Flipnotize21's Avatar
Default Question......
I heard that if you take off the ECU will it effect the imobilizer??? can you start the car again if you unpluged & placed it back???
Old Oct 31, 2006 | 04:16 PM
Bighec1182's Avatar
Default Re: Question...... (Flipnotize21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flipnotize21 &raquo;</TD></TR><TR><TD CLASS="quote">I heard that if you take off the ECU will it effect the imobilizer??? can you start the car again if you unpluged & placed it back???</TD></TR></TABLE>
I do not think it will create any problems.
royalfelix
Feb 27, 2007 04:24 PM
Soon 2BE
Oct 28, 2006 01:26 PM
HondaJon
Aug 9, 2005 06:35 PM
streetspeed607
May 11, 2004 07:18 PM
SPLNRSX
Jan 18, 2004 09:24 AM
