6th generation civic swap ????
Old May 5, 2002 | 04:38 PM
JoHn CoNrOe's Avatar
Default 6th generation civic swap ????
i have a 97 ek and have a b16a2 fom a si but i have da complete swap can i jus use the 99 wire harness and ecu ....if not is there a way to wire it up to 99..
Old May 5, 2002 | 05:04 PM
fowler!'s Avatar
Default Re: 6th generation civic swap ???? (JoHn CoNrOe)
don't use the harness or the ecu.
My suggestion:
1. 96-98 Civic Ex harness
2. Reprogrammed P28 ecu (92-95 Si/Ex)
3. OBD 2.1 - OBD 1 harness.
That will be the easiest way to do it.
HXMan's Avatar
You will have to use your 97 harness. Also, to use the 99 ECU you will either have to rewire all the ECU connector pins, or make an adaptor.
Oh, BTW, complete sentences do help.
Old May 5, 2002 | 05:34 PM
fowler!'s Avatar
Default Re: 6th generation civic swap ???? (Mad HXMan)
I win
TK_209
Oct 8, 2009 12:38 PM
xtreme412
Jan 10, 2006 05:53 PM
ITR#465
May 2, 2003 06:21 PM
94CivSi
Jan 31, 2003 10:36 AM
