DA brake hub and knuckles
Gunna swap out my HF ones for my swap...
question...
How much do they usually go for?
this other guy is selling me them for 150 and the rotors are slotted. is that a good deal?
this other guy is selling me stock ones for 75
question...
Slotted rotors doesnt make a noticeable braking change/improvement. May keep fade away longer cool a little quicker on track bit very minimal. Slotted rotors are more for looks. Id get stock for $75.
My suggestion is buy the stock rotors and save money for bigger MC from integra or EX, or save for rear disc from Si. Something that will make a <U>noticeable</U> difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b ef boy »</TD></TR><TR><TD CLASS="quote">slotted rotors are better because it allows heat to exscape and common since will tell u with rotors less heat resistance less stoping distance duh!!</TD></TR></TABLE>
HA HA HA HA HAH AHAHAHAHAHAHAH....it really does nothing. It still builds the heat and it is more prone to cracking. You are better off running a good vented blank then drilled or slotted. If you must have the hotness then slotted is better than drilled due to the stress risers that will cause the drilled rotors to crack like and SOB. I have run them on the track and they did nothing there was no difference so I save my money and run the Brembo blanks.
I also now have the EX knuckles, ITR calipers, redrilled Prelude rotors, 260v Non ABS Integra booster and MC, and stock ITR pads.
if i just use the stock MC, how bad do i gotta step on the brakes for it to work? and do i need a proportioning valve too? and cant i just use a EF Ex MC or Prelude MC without changing the stock booster?
AndThenYouSay
51
May 21, 2011 04:01 AM
..::91TEG-G2::..
Nov 24, 2005 02:12 PM
ComCool
Feb 24, 2005 07:34 AM
jefe
Nov 21, 2004 06:56 PM
