axle clunking/popping out passenger side/ aftermarket mounts and LSD
Old Oct 24, 2006 | 12:07 PM
92jdmhatch's Avatar
Default axle clunking/popping out passenger side/ aftermarket mounts and LSD
I have a 1992 Civic Hatchback..i just put a new motor in there and everytime i make a right turn there is a loud clunk and the car hops...sounds like its coming from the right axle...my setup is
Ls Block - Gsr Tranny....as far as my motor mounts my driver side one is a Innovative..my tranny one is a place racing...and the rear one is the haasport one...i also have a Obx LSD in my tranny.... the axle i was using was an oem axle...i changed that out to a autozone reman axle...and it gave me the same problem....the last time i drove it...i made a quick right...and the axle clunked but sounded a little worst this time...and wen i was driving on the straight road after that. the car drove as if it was hopping..i got home..i put a flathead screwdriver between the axle and gently pushed back...the axle came out about 4 inches...
any ideas?
also the car drives fine wen i drive straight and shifts smooth
Old Oct 25, 2006 | 11:19 PM
toofast4u752's Avatar
my guess is the lsd. its the only thing i can see that could do that. i have the obx too but no problems with mine. does the axle show any irregular wear on the tranny side when you pulled it?
Old Oct 26, 2006 | 12:57 AM
92jdmhatch's Avatar
Default Re: (toofast4u752)
no
Old Oct 26, 2006 | 01:26 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (92jdmhatch)
Thats strange, I have had a similar issue but not that bad.
Is the car slammed?
Old Oct 26, 2006 | 03:23 PM
Wes V's Avatar
Default Re: (JDM_Ej)
Is it possible that the differential doesn't have the grooves that the axle retention clip snaps into??
Just a thought.
Wes
Old Oct 30, 2006 | 08:29 AM
knar's Avatar
92jdmhatch could you please contact me at knaracing@hotmail.com
about your bisimoto header
sorry for the OT
topp_dawg_g
May 25, 2008 06:17 PM
champLSinteg
May 24, 2007 08:11 AM
92jdmhatch
Oct 24, 2006 02:10 PM
92jdmhatch
Oct 24, 2006 12:45 PM
longuyen88
Jun 16, 2006 09:41 PM
