obd-0 converted into obd-1...i have a ?
Old Oct 24, 2006 | 11:01 AM
itellyawhat's Avatar
Default obd-0 converted into obd-1...i have a ?
So i have a obd-0 car and converted to obd-1. I have a check engine light on...no biggy but want it fixed and turned off. How do I go about check to see what the computer is have a problem with and turn it off?
Thanks,
Jason
Old Oct 24, 2006 | 11:10 AM
Coltmorris's Avatar
Default Re: obd-0 converted into obd-1...i have a ? (itellyawhat)
ahh yess the age old question haha one im still trying to answer! Did you put in a 4wire o2? w/ the correct harness? what motor is this? The best way to figure out what code your throwing is to jumper the ecu. Look around in there and you should see alittle plug that goes to the D4 pinout...put both ends of a paperclip in there and jumper it
Old Oct 24, 2006 | 11:14 AM
NikoZai's Avatar
Default Re: obd-0 converted into obd-1...i have a ? (Coltmorris)
you prooobably need to read the instructions:
http://rywire.com/store/faqdes...id=22
And you prooobably should read how to check your codes:
http://rywire.com/store/faqdes...id=10
(it flashes the same, this will tell you how to read the flashes - ignore that it says OBD0)
And you poooobably need to learn how to fix those codes:
http://www.norcalcrx.org/library/ (crx workshop manual in PDF)
There are troubleshooting guides for each code. Minus VTEC etc lol
Old Oct 24, 2006 | 07:26 PM
thanks^ good responce but still didnt help. I know how to check for codes if u haven't done a swap that changed ur obd. if it was obd0 the ecu has a light.. and obd1 has that lil plug to jump and look at the light on dash. I guess its a wire that needs to be disconnected(2of them)....
Jdmefsir12
Jul 1, 2012 08:13 PM
cannouu
Engine Management and Tuning
Jun 28, 2012 10:17 AM
chriscool888
Jan 3, 2012 01:27 AM
akurtzer57
Aug 2, 2010 01:20 PM
cor4ey
Dec 20, 2008 12:42 PM
