Running a d15z1 on uberdata?
Old Oct 23, 2006 | 10:18 PM
brg2nr's Avatar
Default Running a d15z1 on uberdata?
Here's the scoop, I have a d16z6 with p28 chipped ecu. The engine burns oil so I was going to get a d15z1 for FREE. Problem is that it needs an ecu which is why the guy is just giving it to me.
I have searched on the uberdata forums and found nothing about a bin for a p07 (92-95 VX). Does anyone know if it is possible to run the d15z1 effeciently with a chipped p28?
The problems I foresee are: Vtec E and the wideband O2. (change out the O2 and not worry about vtec engagement? or what?)
Old Oct 23, 2006 | 10:42 PM
Sleepy_Red_hatch's Avatar
Default Re: Running a d15z1 on uberdata? (brg2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brg2nr &raquo;</TD></TR><TR><TD CLASS="quote">Here's the scoop, I have a d16z6 with p28 chipped ecu. The engine burns oil so I was going to get a d15z1 for FREE. Problem is that it needs an ecu which is why the guy is just giving it to me.
The problems I foresee are: Vtec E and the wideband O2. (change out the O2 and not worry about vtec engagement? or what?)</TD></TR></TABLE>
set the VTEC engagement point for 3000 RPM, like a stock VX's....that simple.
Old Oct 24, 2006 | 07:46 PM
specv5150's Avatar
I ran my Y5 (essentially a Z1....same priciple) fine with a chipped P28. Of course, I rewired my car for 4wire oxygen sensor.
Old Oct 24, 2006 | 08:53 PM
Bense's Avatar
just get a chip with p07 maps burned in?
Old Oct 24, 2006 | 09:10 PM
brg2nr's Avatar
I was thinking Turbo D15Z1... I originally thought that the z1's vtec point is at multiple points. (I think I'm wrong..)
I guess we'll try a p07 bin and work it out from there. Anyone happen to have one?
Old Oct 24, 2006 | 09:13 PM
Bense's Avatar
Default Re: (brg2nr)
pgmfi.org has them. i forget which one worsk
Old Oct 26, 2006 | 07:54 AM
brg2nr's Avatar
Bump for more help.. thx
Old Oct 26, 2006 | 08:28 AM
Bense's Avatar
your question has been answered.
run the d15z1 with the correct ecu.
timing maps on the d15z1 are COMPLETELY different from d16z6 maps.
Old Oct 30, 2006 | 08:07 PM
lambertincorp's Avatar
Default Re: (Bense)
what about tuning a d15z1 turbo on a vafc?
Old Oct 30, 2006 | 08:13 PM
F20Cteg's Avatar
Default Re: (lambertincorp)
Simple, go to PGMFI and find the P07-L01 or P07-L02 bin. Use that in your P28. That bin is for the California models which didn't use a wideband O2 sensor. They just used a 4 wire.
The 5 wire bin will not work at all in a P28 or any other ecu except the P07-A## ecus.
Old Oct 30, 2006 | 09:13 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lambertincorp &raquo;</TD></TR><TR><TD CLASS="quote">what about tuning a d15z1 turbo on a vafc?</TD></TR></TABLE>
Can be done. I did it with my Y5 the first time. Worked okay. actually but there is no need. The price of the VAFC can get you a chipped ECU with a vast amount of options. I went witht eh VAFC the first time because I didnt want to rewire my wiring harness for a 4wire among other things. VAFC's are worthless when you have chipped ECU's. An uberdata (or like program) basemap will probably work better than a VAFC
riceordie
15
Sep 20, 2011 10:19 AM
slor209
24
Nov 12, 2006 06:09 PM
Stealth-94eg
Sep 1, 2005 05:50 PM
pootsiracer
Oct 19, 2004 10:09 PM
lelopez
Apr 9, 2002 04:50 AM
