Front Endlink Bolt Question
Old Oct 23, 2006 | 04:59 PM
BlueIntegraBoy's Avatar
Default Front Endlink Bolt Question
I put on a GSR front sway about 3-4 weeks ago. Up until about 3-4 days ago, I noticed a "thunk" noise when I drive and hit bumps or rough road. Today I jacked up the car to see if the endlink nunts were loose. I tried tightening the top endlink nut, but it kept free spinning. Does the top nut that connects the endlink to the sway bar supposed to free spin when it's fully tightened?
If I can eliminate the areas that might cause the "thunk" noise, I can perhaps try and pinpoint where it's coming from. I also suspect my springs are making the "thunk" noise because I believe my struts are going.
Old Oct 23, 2006 | 05:02 PM
EG2Driver's Avatar
Default Re: Front Endlink Bolt Question (BlueIntegraBoy)
when my car did that i had a broken end link. How is it shaped on ur car? L or I shaped?
Old Oct 23, 2006 | 05:35 PM
Default Re: Front Endlink Bolt Question (DeadEnd9009)
L shaped
Old Oct 23, 2006 | 06:18 PM
EG2Driver's Avatar
shitty when those go out, they're expensive as hell. I had to pay 115 bucks CDN for mine...Make sure they're not broken.
Old Oct 23, 2006 | 07:55 PM
How do I know if they are broken or not?
Old Oct 23, 2006 | 08:32 PM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">How do I know if they are broken or not?</TD></TR></TABLE>
lol You'll know if its broken, nothing is hidden under a boot or anything.
Old Oct 23, 2006 | 08:40 PM
I think one endlink has the boot torn.
Old Oct 24, 2006 | 05:17 AM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">I think one endlink has the boot torn.</TD></TR></TABLE>
if the boot is torn, the "ball" might not get proper lube and will eventually fail. But u live in hawaii, there is no salt or anything like that. You could replace it, but its up to you.
Old Oct 24, 2006 | 12:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">
if the boot is torn, the "ball" might not get proper lube and will eventually fail. But u live in hawaii, there is no salt or anything like that. You could replace it, but its up to you.</TD></TR></TABLE>
Not at $50 a pop
Old Oct 24, 2006 | 06:01 PM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Not at $50 a pop </TD></TR></TABLE>
I got mine for 115.....consdier 50 bucks cheap.
bbbsti
Honda CR-V & Element
10
Nov 26, 2010 02:54 PM
7808
Dec 30, 2007 05:07 PM
rathead81
Sep 22, 2006 03:27 PM
js2k01
Honda S2000
Jun 12, 2005 02:21 PM
MachAF
Aug 9, 2002 07:37 PM
