ZC problems
Old Oct 23, 2006 | 04:06 PM
hondaboy90's Avatar
Default ZC problems
ok i just put a dohc zcc in my car (89 crx hf) and it will not start it cranks but it will not start ive checked everything i can think of but it still persists
one question though when you check for spark my spark plugs only spark one time then thats it is taht normal?
Old Oct 23, 2006 | 04:12 PM
kingSfit's Avatar
check your distributor if you are getting any spark . are you throwing any codes? if anything try replacing your cap / rotor
Old Oct 23, 2006 | 04:15 PM
hondaboy90's Avatar
Default Re: (BUN-MINO)
replaced the rotor and cap today and im just getting one spark from my plug when i first turn the key then it doesnt spark anymore after that
placid888's Avatar
Default Re: ZC problems (hondaboy90)
remember the basic, COMPRESSION, FUEL, & SPARK
Old Oct 23, 2006 | 04:22 PM
hondaboy90's Avatar
Default Re: ZC problems (placid888)
compressions good fuels good spark is the only thing im concerned about
Old Oct 23, 2006 | 04:34 PM
problem_si's Avatar
what distributor did you use?
Old Oct 23, 2006 | 04:39 PM
hondaboy90's Avatar
Default Re: ZC problems (problem_si)
its a 88-89 integra distributor and the new cap, rotor, and ignition module are for a crx si
Old Oct 23, 2006 | 07:03 PM
problem_si's Avatar
i didn't know that you could use that one...
anywho, check your connections at the dizzy plug. If you did this swap you had to remove pins from one side of the plug or the other.
who knows, maybe you have a loose connection or something..
good luck
Old Oct 24, 2006 | 06:21 PM
hondaboy90's Avatar
ok update im getting codes 8 and 15
8's for TDC
and15's for ignition output signal
so does this basically mean i should get a new distributor?
Old Oct 24, 2006 | 10:38 PM
problem_si's Avatar
Default Re: (hondaboy90)
what ecu are you using?
Old Oct 25, 2006 | 04:13 AM
hondaboy90's Avatar
Default Re: (problem_si)
the PG7
Old Oct 25, 2006 | 06:24 AM
El pimp chulo's Avatar
my car was throwing a code 8 and i think it was a 14 i changed the wires, cap, rotor, dizzy, spark plugs and rotor and now more problem just the ting is my battery is too big and keeps knocking out my wires from my cap
Old Oct 25, 2006 | 10:00 AM
adeline's Avatar
Default Re: (El pimp chulo)
you can not use the ignition module from a crx si. That is were your problem is right their. use the intrega module
Old Oct 25, 2006 | 11:30 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (adeline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline &raquo;</TD></TR><TR><TD CLASS="quote">you can not use the ignition module from a crx si. That is were your problem is right their. use the intrega module </TD></TR></TABLE>
x2
Old Oct 25, 2006 | 02:06 PM
hondaboy90's Avatar
Default Re: (wiZCo)
sorry i didnt notice that but the ignition module is from a 88-89 integra
just the cap and rotor are from the crx si
Old Oct 25, 2006 | 02:29 PM
problem_si's Avatar
I used my entire dizzy from my Si hatch, including igniter, and everything worked fine.
Old Oct 25, 2006 | 05:51 PM
jlicrx's Avatar
do you have the HF engine harness on the ZC? if not, you will get code 15 because the igniter wire in the HF harness is in a different connector
Old Oct 25, 2006 | 07:02 PM
hondaboy90's Avatar
Default Re: ZC problems (jlicrx)
no
how do i fix it
Old Oct 25, 2006 | 07:29 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboy90 &raquo;</TD></TR><TR><TD CLASS="quote">how do i fix it </TD></TR></TABLE>
use the 89 HF harness - there are several wires in different locations in the HF connectors
Old Oct 26, 2006 | 06:45 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by problem_si &raquo;</TD></TR><TR><TD CLASS="quote">
I used my entire dizzy from my Si hatch, including igniter, and everything worked fine.</TD></TR></TABLE>
He used the integra dizzy.
Old Oct 26, 2006 | 01:54 PM
hondaboy90's Avatar
i kinda dont have the crx hf harness or i wouldve used it first so is their any way i can fix it without getting a new harness my car needs to run i get my license in two weeks
Old Oct 26, 2006 | 02:51 PM
hondaboy90's Avatar
ok i checked out all of the wiring the only things i can see missing are
on the injector resistor box theres a white wire and a yellow wire missing
not on the green plug but the whittish one
and for some reason now my fuel pump isnt priming and im still not getting spark and my injectors arent spraying obviously
another thing is my ecu wont blink at all any more
but the motor still cranks
does this mean i need a new main relay
Old Oct 26, 2006 | 03:08 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboy90 &raquo;</TD></TR><TR><TD CLASS="quote">on the injector resistor box theres a white wire and a yellow wire missing
not on the green plug but the whittish one</TD></TR></TABLE>
You may not be getting power to the injectors...
How are you checking for spark? Also, take off the dizzy cap, and get a friend to crank it. see if the rotor is spinning. If it is, your timing belt is intact.
Check the timing marks on the cam and crank pulley to see if your off time. Even if you have spark and fuel it won't matter if they aren't hapening at the right time.
Could be main relay if the fuel pump isn't priming...
Old Oct 26, 2006 | 03:19 PM
hondaboy90's Avatar
Default Re: ZC problems (Tippyman)
ok this motor was just rebuilt
so belt is new i know its in perfect condition my timing should be perfect bot arrows on the cams are facing up and the lines are lined up
it'll spark one time sometimes but none after while the motor is cranking
Old Oct 29, 2006 | 06:38 PM
hondaboy90's Avatar
ok i have a new harness in the mail specifically for a 89 crx hf so once i get it that should fix my problem theoretically
halocore
Jan 8, 2010 04:20 PM
97civic07gsxr
10
Apr 6, 2009 07:16 AM
coldpimpin
Apr 10, 2007 08:41 PM
ILOVEGIRLS
Apr 19, 2006 07:52 PM
HADDENWORKS
Jul 4, 2005 05:40 PM
