radiator fan
i put in a new radiator and its working fine... now im having troble with the fan.. i don't thing it turns on... the wire is connected is their away i can trigger it to run or to see if it works before i run off and replace it?
i dont have a.c. nomore .. i need to get that ven. for it plus the fan.. but for some stupis reason this fan wont turn on .. ill play with the wires again .. and see what i can do with the battary.. any other suggestions?
run some jumper wires from the harness plug on the fan to the battery and see if it turns on. if it does turn on, its your coolant temp switch that went out. that switch controls when the fan comes on. g/l
deerman2701
Dec 13, 2012 07:25 PM
dudeomega2000
Jan 6, 2008 09:51 PM
