Getting my muffler off
Old Oct 23, 2006 | 10:58 AM
totsie7944's Avatar
Default Getting my muffler off
Hey I need to get my exhaust off my R to cut a section out to fit my new SMS header.
I have a SMS exhaust, magnaflow muffler...I got the bolts out, but I can't get the dam muffler off, the pipes are like seized together. Any suggestions?
Old Oct 23, 2006 | 11:04 AM
PrinceAli132's Avatar
Default Re: Getting my muffler off (totsie7944)
Where do you think they are seized at? The flange?
Did you remove the exhaust hangers or the little rubber pieces that hold them to the body.
Ali
Old Oct 23, 2006 | 11:08 AM
exies's Avatar
I ran into a problem like this before. What I ended up doing was getting a torch and heat up the joint. I then began to pound the muffler until it came loose. The muffler was dented from all the pounding, but it was going to be tossed anyways. Maybe the heat will soften it enough for you to pull it apart instead of pounding it.
Also it took two people to do this, one to beat the muffler and one to catch it when it broke loose.
Hope that helps.
Old Oct 23, 2006 | 11:11 AM
walker111's Avatar
Default Re: Getting my muffler off (exies)
You could also drop the rear LCA and just drop the exhaust as a whole. Should give you more leverage...
Old Oct 23, 2006 | 11:27 AM
Jon D's Avatar
torch solves all... just make sure you lube it with never sieze before putting it back on.
Old Oct 23, 2006 | 11:47 AM
walker111's Avatar
Default Re: Getting my muffler off (Jon D)
Is this a slip fit exhaust? If not I dont understand which part is seized together....
Old Oct 23, 2006 | 11:53 AM
Jon D's Avatar
Default Re: Getting my muffler off (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Is this a slip fit exhaust? If not I dont understand which part is seized together....</TD></TR></TABLE>
yeah i confused now too.
Old Oct 25, 2006 | 11:26 AM
totsie7944's Avatar
umm the muffler pipe goes around the pipe coming off the exhaust...about 4 inches worth I would guess....i got a screw driver in between the flange and beat it in to seperate the flanges like 1/4" but still have alot to go...
so I take it heating it with a torch is the reccommended solution?
Old Oct 25, 2006 | 11:34 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">umm the muffler pipe goes around the pipe coming off the exhaust...about 4 inches worth I would guess....i got a screw driver in between the flange and beat it in to seperate the flanges like 1/4" but still have alot to go...
so I take it heating it with a torch is the reccommended solution?</TD></TR></TABLE>
Confusing, but I think you mean its a slip fit. have you sprayed it with pb blaster? I would still recommend dropping the whole exhaust for better leaverage...
Old Oct 25, 2006 | 11:48 AM
exies's Avatar
Hm, four inches? That's a pretty large area to torch. You might want to try Jim's idea.
Old Oct 25, 2006 | 11:53 AM
walker111's Avatar
Default Re: (exies)
My hytech is close to 4 inches also.
HYTECH FTW!!
Old Oct 25, 2006 | 11:57 AM
totsie7944's Avatar
Confusing, but I think you mean its a slip fit. have you sprayed it with pb blaster? I would still recommend dropping the whole exhaust for better leaverage...</TD></TR></TABLE>
i haven't sprayed it with anything...since I have to pay someone to cut and weld the exhaust anyway, I figured I would just pay them to take care of it all lol
Old Oct 25, 2006 | 11:59 AM
walker111's Avatar
They might charge extra, and also might say that they need to replace it
Old Oct 25, 2006 | 12:00 PM
totsie7944's Avatar
they better not try and replace that dam muffler....its our family mechanic so hes usually a good guy...
Old Oct 25, 2006 | 12:03 PM
walker111's Avatar
That should work out then. It will be alot easier with power tools and a lift!
Old Oct 25, 2006 | 12:10 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">That should work out then. It will be alot easier with power tools and a lift!</TD></TR></TABLE>
thats what im thinking to... i had air tools and a compressor, but air tools can't pull off a muffler lol.
Old Oct 25, 2006 | 12:13 PM
walker111's Avatar
Yea, but they'll take off the lca real quick
Old Oct 25, 2006 | 12:21 PM
totsie7944's Avatar
very true....its too bad I didn't think of that and just drop the whole exhaust cause everything else is just hanging on the ground right now, all rubber bands off and everything
Old Oct 25, 2006 | 12:22 PM
totsie7944's Avatar
actually if i did that...i could leave the muffler....
Old Oct 25, 2006 | 12:23 PM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">You could also drop the rear LCA and just drop the exhaust as a whole. Should give you more leverage...</TD></TR></TABLE>
Old Oct 25, 2006 | 12:27 PM
totsie7944's Avatar
yea I will have to do that sunday lol
Old Oct 25, 2006 | 12:35 PM
exies's Avatar
LoL It's funny you need to quote yourself when people just don't read the post.
integracura
May 5, 2006 08:23 AM
adam_mcd
Jan 11, 2006 06:34 PM
LostCRX
Apr 20, 2005 05:34 PM
