turbo k20's with stock internals
i was searching a little bit and it seems like the majority of people that have a turbo set up are running with stock internals. for the people that are running on stock internals, how much boost are you pushing and on what kit. to run around 7 or 8 psi on a cybernation kit, would it be sufficient to just get a good tune and not have to mess with the inside stuff? 250-280 whp is what im thinking max.
Which motor are you thinking of boosting? I wouldn't puch much over 10 lbs on a A3 motor, maybe nothing over 6-7 lbs on an A2 (I'm not really familiar with boosting an A2 so that is just a guess). Of course you are going to need bigger injectors (550-650 cc/min), ECU upgrade (K-Pro or EMS), Full Exhaust (3 in.), etc etc. Looks like you wanna stay under 300 whp ... I haven't really heard good things about the quality of the cybernation kit. The Greddy kit is pretty complete once you get the intercooler ... EManage is crap. You might be able to pull off your numbers with the Greddy kit. If you were looking for the best setup ... with some room to grow I would go with any kit by Full Race. I ordered their stage 1 kit ... should be able to hit around 300 whp with 10 psi easy.
The quality of the kit is 2nd to none ...
Just all comes down to how much money you want to spend ... I suggest you spend a little more up front and get everything done right the first time vs. spending money here and there fixing crap all the time! Just my .02
Check them out ... http://www.full-race.com
The quality of the kit is 2nd to none ... Just all comes down to how much money you want to spend ... I suggest you spend a little more up front and get everything done right the first time vs. spending money here and there fixing crap all the time! Just my .02
it would be an a2, it would be my daily as well. commuting from home to school to work, driving in snow/rain, roadtrips, do you think that it would fair alright given that i get the tuning/fuel delivery done? thanks for the input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullEP3 »</TD></TR><TR><TD CLASS="quote">Which motor are you thinking of boosting? I wouldn't puch much over 10 lbs on a A3 motor, maybe nothing over 6-7 lbs on an A2 (I'm not really familiar with boosting an A2 so that is just a guess). Of course you are going to need bigger injectors (550-650 cc/min), ECU upgrade (K-Pro or EMS), Full Exhaust (3 in.), etc etc. Looks like you wanna stay under 300 whp ... I haven't really heard good things about the quality of the cybernation kit. The Greddy kit is pretty complete once you get the intercooler ... EManage is crap. You might be able to pull off your numbers with the Greddy kit. If you were looking for the best setup ... with some room to grow I would go with any kit by Full Race. I ordered their stage 1 kit ... should be able to hit around 300 whp with 10 psi easy.
Check them out ... http://www.full-race.com</TD></TR></TABLE>
one of the best/most educated posts ive seen around here
just in turbo charging rsx's in genera, it likes like an extremley tight fit, has anyone had trouble with heat problems or anything?
you will need to wrap pretty much everything along your firewall ... or move it and reinstall in a different location. You will need some sort of shielding for your hood if you want your paint to stay nice ... the heat will destroy it. Get a heat shield for the turbine housing ... that will help. I would suggest rerouting your fuel line as well ... it runs pretty close to where your turbo will sit.
Full Race produces a turbo mani that places the turbo more beside the driver side of the motor vs behind it to give you more room. Check it out ...
It is uber tight back there ...
the reason im keeping the whp goal pretty modest is that i want a decently reliable daily as well. like i said before this car does everything from taking me to school to take me around the country so i would prefer something that wont blow up. oh and with my power goal will upgrading to a walbro 255 be neccessary doesnt seem like many people with the stage 1 kit upgraded the pump, just the injectors
Modified by nathanie1 at 10:39 PM 10/23/2006
Man save you money and get a supercharger you can easily make the numbers you'r looking for with one and probably come out with a better pwoer band
Check out the jackson racing unit or the comtech
haha im inquiring about this kit in particular because i have a chance to pick on up for close to nothing
Modified by nathanie1 at 4:31 PM 10/24/2006
I have been running the Greddy kit for 15000+ miles...only problems that I had were because of e-manage. I had my ecu reflashed by hondata for the greddy kit and has been running great since. I have heard of a lot of people having problems with Cybernation's guardian but other than that it is supposed to be a good kit.
yea ive been hearing that as well, and after researching it a lil im not suprised but im curious to know if ANYONE has EVER been satisfied with the guardian
thats a stock K24 (CRV or accord, i forget) block and A2 head...
There are plenty of people making OVER 400 hp on stock k20A2's...
check out http://www.k20a.org and http://www.k-series.com for better K info.
Hank
Hank
