Installing JDM front conversion
i know i have to cut the radiator support and point weld it on but honestly is it something that i need to take to a shop to do? or is it easy to be done like it seems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lostsonta »</TD></TR><TR><TD CLASS="quote">
My friend tried to weld it on himself and welded it on backwards. </TD></TR></TABLE>
I'm sorry...but.....
hahahahahahahahahahhahaha.......I don't know why I found that so funny....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-rush08 »</TD></TR><TR><TD CLASS="quote">i know i have to cut the radiator support and point weld it on but honestly is it something that i need to take to a shop to do? or is it easy to be done like it seems?</TD></TR></TABLE>
yeah if you're not an experienced welder then at least get someone to do that for you. everything else can be installed pretty easily.
i've seen it done before, you cut the top half of the us radiator support and throw it away and cut the top half of the JDM radiator support and tack weld it on the us one, than its all bolt on after that... pertty simple. I would do it but im to cheap to get a JDM front end lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-rush08 »</TD></TR><TR><TD CLASS="quote">what do you mean by drill out the welds?? instead of cutting the rad support drill it and the cut or what??</TD></TR></TABLE>
Drill out the spot welds man.
cutting the top half of the us radiator support and throw it away and cut the top half of the JDM radiator support and tack weld it on the us one, than its all bolt on after that...
is that bad thing to do or should i drill out the welds and put the whole new one on??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redJDMDC2 »</TD></TR><TR><TD CLASS="quote">try this
http://www.masetuning.com/jdmc....html</TD></TR></TABLE>
nice
nice
standbackimapro
25
May 22, 2024 12:35 AM
