Installing JDM front conversion
Old Oct 22, 2006 | 10:20 PM
D-rush08's Avatar
Default Installing JDM front conversion
i know i have to cut the radiator support and point weld it on but honestly is it something that i need to take to a shop to do? or is it easy to be done like it seems?
Old Oct 22, 2006 | 10:25 PM
lostsonta's Avatar
Default Re: Installing JDM front conversion (D-rush08)
Can you weld? If not, take it to someone that can.
My friend tried to weld it on himself and welded it on backwards.
Old Oct 22, 2006 | 10:45 PM
Naruto's Avatar
Default Re: Installing JDM front conversion (lostsonta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lostsonta &raquo;</TD></TR><TR><TD CLASS="quote">
My friend tried to weld it on himself and welded it on backwards. </TD></TR></TABLE>
I'm sorry...but.....
hahahahahahahahahahhahaha.......I don't know why I found that so funny....
Old Oct 22, 2006 | 11:12 PM
.wtf's Avatar
Default Re: Installing JDM front conversion (Naruto)
how the heck you weld it on backwards
Old Oct 23, 2006 | 07:34 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-rush08 &raquo;</TD></TR><TR><TD CLASS="quote">i know i have to cut the radiator support and point weld it on but honestly is it something that i need to take to a shop to do? or is it easy to be done like it seems?</TD></TR></TABLE>
yeah if you're not an experienced welder then at least get someone to do that for you. everything else can be installed pretty easily.
Old Oct 23, 2006 | 09:34 PM
Kangolbrand's Avatar
i've seen it done before, you cut the top half of the us radiator support and throw it away and cut the top half of the JDM radiator support and tack weld it on the us one, than its all bolt on after that... pertty simple. I would do it but im to cheap to get a JDM front end lol.
Old Oct 24, 2006 | 02:09 PM
99DCteG's Avatar
yea just do it yourself, if you can even somewhat weld you can do it. but dont cut the rad support drill out the welds.
Old Oct 26, 2006 | 02:07 PM
D-rush08's Avatar
Default Re: (integras_are_best)
what do you mean by drill out the welds?? instead of cutting the rad support drill it and the cut or what??
Old Oct 26, 2006 | 02:10 PM
DC5Danny's Avatar
Streets closed Pizzagate boy
Default Re: (D-rush08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-rush08 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by drill out the welds?? instead of cutting the rad support drill it and the cut or what??</TD></TR></TABLE>
Drill out the spot welds man.
Old Oct 26, 2006 | 02:22 PM
mike9571's Avatar
Default Re: (DC4Dan)
There is no cutting involved. Possibly some chiseling but absolutely no cutting. Spot welds are the little round indentions.
Old Oct 29, 2006 | 09:33 PM
D-rush08's Avatar
Default Re: (mike9571)
cutting the top half of the us radiator support and throw it away and cut the top half of the JDM radiator support and tack weld it on the us one, than its all bolt on after that...
is that bad thing to do or should i drill out the welds and put the whole new one on??
Old Oct 29, 2006 | 10:04 PM
B18 Piston's Avatar
Bodyshop
Old Oct 31, 2006 | 12:08 PM
redJDMDC2's Avatar
try this
http://www.masetuning.com/jdmc....html
Old Nov 1, 2006 | 07:51 AM
B18 Piston's Avatar
Default Re: (redJDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redJDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">try this
http://www.masetuning.com/jdmc....html</TD></TR></TABLE>
nice
standbackimapro
25
May 22, 2024 12:35 AM
ls_bitik
Northern California (Sales)
Oct 20, 2008 05:29 PM
HT Chaplain
Welding / Fabrication
12
Dec 1, 2007 04:13 PM
OUT_OF_ORDER_DB7
Oct 4, 2007 07:12 AM
RSVTECDC4
Apr 1, 2004 07:36 PM
