Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
110 4th gear
Old Oct 22, 2006 | 09:00 PM
volcom1887's Avatar
Default 110 4th gear
My Em2 stops at 110 in 4th and i knows its in my ecu that doesnt let me go over but can i get a chip or something that changes that?
Old Oct 22, 2006 | 09:58 PM
sixfiveoh's Avatar
Sweet Title
Default Re: 110 4th gear (volcom1887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volcom1887 &raquo;</TD></TR><TR><TD CLASS="quote">No really it that what I really do wow thats all omg your so smart. It stops at 110 even if i switch to 5th</TD></TR></TABLE>
lol your governor is at 110?
Old Oct 22, 2006 | 10:13 PM
volcom1887's Avatar
Default Re: 110 4th gear (sixfiveoh)
yeah i can go 110 in 4th not even redlined and switch to 5th and it doesn't go any farther besides going down a bridge i was going 120 and acted like it wanted to cut off
Old Oct 22, 2006 | 10:17 PM
toyomatt84's Avatar
Sanji
Is there a reason why you're driving 110mph in 4th, regardless of whether or not your car is governed to that speed?
What does it do when you hit 110? Does it cut the throttle, or does it not seem to go faster? Because with the engine that comes with the EM2 you have, 114mph is pretty much it's top speed. You may just be bouncing on the revlimiter, which has nothing to do with governing your speed, and everything to do with maintaining your engine.
Modified by toyomatt84 at 2:04 AM 10/23/2006
Old Oct 22, 2006 | 10:26 PM
volcom1887's Avatar
Default Re: (toyomatt84)
Please learn to read better. I have an Em2 for one. To answer your question it just dont go over 110 besides going down a steep brigde then the throutte cuts out at 120. All I want to know it what can i do to my ecu to make wear i can switch to 5th and not stay at 110
Modified by volcom1887 at 12:05 AM 10/23/2006
Old Oct 22, 2006 | 11:12 PM
toyomatt84's Avatar
Sanji
Default Re: (volcom1887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volcom1887 &raquo;</TD></TR><TR><TD CLASS="quote">Please learn to read better. I have an Em2 for one. To answer your question it just dont go over 110 besides going down a steep brigde then the throutte cuts out at 120. All I want to know it what can i do to my ecu to make wear i can switch to 5th and not stay at 110</TD></TR></TABLE>
The difference in cars is negated, by the fact that you've got the same engine/drivetrain. The only difference is 80lbs and 2 doors, which isn't enough to change my prior statement. At 114mph, your car is about 100% tapped for power, that's why you can't go past 110, without the use of a hill.
To answer your question directly, there isn't an ECU or chip to change your top speed, because there isn't a speed cutoff to begin with.
Oh, and for the record, if you're going to use the term "for one", you've got to have a second point to back it up.
Old Oct 22, 2006 | 11:27 PM
volcom1887's Avatar
For the record......... Its not taped out when i switch to 5th im running like 4000 rpms and cruising at 110. All I wanted to know is if they sell a chip for my ecu or if anyone knew anything else so it will go to its full potential in 5th gear, but i know that i can get a single ecu and get my engine tuned and it would cost alot of money i wanted to know if theres a cheaper way to get what i wanted. Thanks
Old Oct 22, 2006 | 11:28 PM
brjhnson's Avatar
Modified by volcom1887 at 12:05 AM 10/23/2006</TD></TR></TABLE>
dont come into honda-tech bitching at people like matt. He knows what he is talking about. There is no need to go over 90 let alone 110. Grow up, you are going to end up killing some one going that fast. I already do not like you for bitching about stupid *** ****.
wow full potential in a em2 with a d17 is 32 mpg not going over 110mph
Old Oct 22, 2006 | 11:40 PM
Curiouz_G's Avatar
i cant begin to describe how wrong of a car you brought if you wanted to go that speed.
Old Oct 22, 2006 | 11:44 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volcom1887 &raquo;</TD></TR><TR><TD CLASS="quote">For the record......... Its not taped out when i switch to 5th im running like 4000 rpms and cruising at 110. All I wanted to know is if they sell a chip for my ecu so it will go to its full potential in 5th gear</TD></TR></TABLE>
What you don't seem to realize, is that your car needs more horsepower to go faster. Regardless of what you may think you know, the top speed of a stock (or next to stock, in your case) D17-based vehicle is 116mph. That would be the EX model with it's extra 10hp from the variable valve timing (referred to as VTEC). The Civic Type-R of the same generation (2002-2004), with a 6-speed transmission (no engine work), barely pulls out 146mph as it's top speed, and it has 196whp. That's twice what you have in your EM2, and it has a 6-speed.
Old Oct 22, 2006 | 11:47 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volcom1887 &raquo;</TD></TR><TR><TD CLASS="quote">okay whats the point of fixing up a car if you dont go over 90 wtf? I've been 150 on my bike mother ****** so tell me im going to kill myself. and so your saying if i turbo my d17 and tune it good it wouldnt go over 110? ******* idiot</TD></TR></TABLE>
Actually, if you turbo'd your car, you would be able to go over 110mph. You might even hit 140mph, if it's tuned properly.
Old Oct 23, 2006 | 05:06 AM
George Knighton's Avatar
H-T Order of Merit
Several points have been taken as a result of disrespectful, TOSsable posts in this thread.
Address each other with respect, regardless of whether or not you agree with something.
It's OK to post a reminder to the thread originator that you (and we) think that patently unlawful speeds on the street is an issue against which we take a stand, but there is no point in bashing him to the point that he loses his temper and causes a violation of the peace.
Old Oct 23, 2006 | 06:19 AM
TN90accord's Avatar
So in 5th you're at 4000 rpms at 110? When I'm in 5th I'm at like 4000 rpms at 80. I don't think my EM2 could run more than 110, it just doesn't have the power or the transmission.
Modified by TN90accord at 10:34 AM 10/23/2006
Old Oct 23, 2006 | 07:16 AM
iwantspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">Actually, if you turbo'd your car, you would be able to go over 110mph. You might even hit 140mph, if it's tuned properly.</TD></TR></TABLE>
so that means if we do modify our motor it will go faster than 116 mph.. kuzz i have intake header and exuast and i know it got alot faster top end and low end than stock. i know i have hit 123-125 but only for a second. there was NOBODY on the the freeway. not to mention on a pretty much stock motor isnt that a bad thing to be doing?
what im trying to get at is. instead of buying a fake chip on ebay. modify your motor then it will go faster...
Old Oct 23, 2006 | 09:01 AM
Vantage's Avatar
going over 110 mph in a car not made for those speeds is just STUPID. Go post on some ricer forums please, i hope no one helps u.
Old Oct 23, 2006 | 10:35 AM
fventura03's Avatar
get vafc2, set it at 4k, when u get to 110mph in 5th it'll kick in, and bam, you'll be at 160mph in no time
Old Oct 23, 2006 | 12:22 PM
oddmut's Avatar
Default Re: (fventura03)
I like to say that in my ES1 if I am correct 4 dr sedan 03. I've gotten it to top out at 135 in 5th gear. With an intake alone on a straight plane, heading towards las vegas. Yes it is stupid doing that **** in a civic but as a guy who likes pushing things to see what it can do it will hit 135 and stop or maybe more. It is close to the redline but won't budge anymore, well for me haha.
Volcom from my knowledge upgrading the ECU will help increase your top end speed and getting rid of your governer will allow you to red line your last gear. Now your top end speed takes a lot more work to change.
My reason behind the governer is that I used to race motocross and some of the dirt bikes come with governers and need to be removed. I had removed mine on the bike.
My other reason behind the ECU is all theoretical. If your car was programmed to run this fast with certain mods it can be programmed to run faster with different mods or the same. Except your looking into buying an expensive ECU.
Old Oct 23, 2006 | 12:41 PM
devani's Avatar
Default Re: (oddmut)
The speedo on the civic is not accurate over 60 mph...
http://www.superhonda.com/foru...=3949
well not only on civics but all cars....
i thought everyone knew that...excluding newbs...
Old Oct 23, 2006 | 12:53 PM
Todd00's Avatar
I said I don't want a title!
Lose the 18" wheels and go to a lightweight 15" wheel and you'll see more than 110 MPH.
Anyhow, think this thread has lived almost long enough...
Old Oct 23, 2006 | 02:47 PM
Honda.F1's Avatar
I Think your problem is a lack of turbo. Once that is installed you should be able to go over 110 mph.
hope there are no deer or such where you are driving this fast, hit one of those at 110 mph and it could be all over for you and the EM2
have you been watching too much Top Gear or something ?
unsafe/fast driving example ---&gt;
http://videos.streetfire.net/v...3.htm
Acura Integra Type R car crash
cheers, be safe
2010crv
Honda CR-V & Element
Nov 20, 2014 08:08 AM
carbonDelSol
Aug 12, 2004 09:34 AM
92jdmhatch
42
Apr 20, 2004 03:50 PM
SPOON DC2
Aug 21, 2003 08:16 PM
BillWalton1
23
May 13, 2003 10:18 AM
