**car dies after warm up**
code of knock sensor and iacv.....got rid of the codes....fixed both knock sensor, and iacv...but the car dies once its warmed up to normal temp...NO CODES....replaced vaccum hoses already...what else could it be?? im a VW guy, im a lil noob with honda sickness..please keep it clean im not here to cause trouble, im here for help....
please help...
thanks
please help...
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">check the fast idle thermal valve, its under the throttle body</TD></TR></TABLE>
i did checked and cleaned.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude »</TD></TR><TR><TD CLASS="quote">do you have any vacuum leaks? what is your idol set at? have you checked the idol with the iacv off? </TD></TR></TABLE>
well i replaced all vaccum hoses, re-check everything, and iavc cleaned and new orings...idol set at 950-1100..cold start ok but after of 15 minutes of driving its dies on idle, when rich normal engine temp....NO CODES
if ECT is bad would that causes the engine to die on honda motors? im still trying to figure out my motor right now....runs good but when its warms up again, on idle it dies.....any more suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrsexxxy »</TD></TR><TR><TD CLASS="quote">if ECT is bad would that causes the engine to die on honda motors? im still trying to figure out my motor right now....runs good but when its warms up again, on idle it dies.....any more suggestions? </TD></TR></TABLE>
No the ect is for the temp guage.
You can have it disconnected and the car will still run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrsexxxy »</TD></TR><TR><TD CLASS="quote">its got fuel and spark...</TD></TR></TABLE>
even after it warms up and wont start?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrsexxxy »</TD></TR><TR><TD CLASS="quote">and im running of ideas what it could be, you know...
would a bad knock sensor switch would do this?</TD></TR></TABLE>
I have had a completely broken off knock sensor and all it did was throw a check engine light.
Check your cam timing and valve clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">
Check your cam timing and valve clearance.</TD></TR></TABLE>
havent check timing yet but ill do that tomorrow
poormans_typer69
Oct 30, 2007 05:10 PM
mongoliandonuts
Sep 21, 2004 06:05 PM
