first time at the track- my time sucks:)
Old Oct 22, 2006 | 04:43 PM
komat's Avatar
Default first time at the track- my time sucks:)
r/t .675 (didnt care for reaction time since its tnt)
60' 2.263
330 6.327
1/8 9.453/85.61mph
1000 11.808
1/4 13.798/111.33,ph
first time at the track with 420hp/312tq b16 tranny. i was on street tire falken azenis 615 launching at 1300-1500rpm. i thought about getting drag radials but it was too late in the season to get full use out of them. the track wasnt prep too well for street tire. i was spinning my tire hardcore in 2nd and 3rd. so i end up riding down the track on 4th. i also shifted early on 4th to 5th. so trap speed would be alot higher too if i just kept on 4th.
so my question is with drag radial and better traction. my trap speed should be alot higher? maybe in the 120s with the power im making? also with the trap speed its currently should be at 12s?
setup is
Benson Sleeve B18b
83mm bore
9:1 CP Pistons
Eagle Rods
ACL bearling
balance and polished crankshaft
Golden Eagle LSVtec Conversion Kit
Golden Eagle GSR Head Studs
Z10 catchcan Kit
B16a 2nd gen Head
SuperTech Valve tran
ITR Cams
BDL cam gears
Hondata Intake Manifold Gasket
AEBS intake manifold
.043" Copper O ring Exhaust gasket
RDL Ramhorn
38mm wastegate
3" dp
3" Exhaust with magnaflow muffler
SC6152e
precision 750hp intercooler
Precision 1000cc injectors
gm 3 bar map
Greddy profec B spec 2 EBC
STOCK SUSPENION with tenzo r lowering spring
http://s42.photobucket.com/alb...9.flv
http://s42.photobucket.com/alb...0.flv
Modified by komat at 9:40 PM 10/22/2006
Old Oct 22, 2006 | 05:30 PM
ludekid4323's Avatar
Default Re: first time at the track- my time sucks:) (komat)
good job
Old Oct 22, 2006 | 07:24 PM
dunkd's Avatar
u had to shift into 5th @ 111mph?
Old Oct 22, 2006 | 09:36 PM
komat's Avatar
Default Re: (dunkd)
i short shifted. tach was off and i kept on forgeting about it
it was my first time at the track so yea **** happens going back on nov 4th with slicks. 11s here i come!
Old Oct 22, 2006 | 10:10 PM
paulzy's Avatar
I watched the first vid and I swear you didn't launch that thing
Old Oct 22, 2006 | 10:25 PM
komat's Avatar
Default Re: (paul vang)
it wasnt a big one just 1300rpm. it wheel hopped off the line so i let go of the gas and stepped on it again.
i wish i had more runs in. i was going a little faster each run.
Old Oct 22, 2006 | 10:38 PM
dunkd's Avatar
Default Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">it wasnt a big one just 1300rpm. it wheel hopped off the line so i let go of the gas and stepped on it again.
i wish i had more runs in. i was going a little faster each run.</TD></TR></TABLE>
thats where some cars idle! try launching that thing at 5k and feathering the clutch.
Old Oct 23, 2006 | 12:09 PM
97gsrki's Avatar
Default Re: (dunkd)
at about 400whp i ran 12.6 at 124 on $70 kumho tires w/o lowering tire pressure. I was launching at about 3500 and just feathering it through 1st 2nd and 3rd. i was cutting 2.1 60's. So i'd say with that power level and dr's you should definatly be well in the 12's. and also i just realized that we have the same crappy suspension. tenzo-r baby haha.
Old Oct 23, 2006 | 12:49 PM
komat's Avatar
Default Re: (97gsrki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97gsrki &raquo;</TD></TR><TR><TD CLASS="quote">at about 400whp i ran 12.6 at 124 on $70 kumho tires w/o lowering tire pressure. I was launching at about 3500 and just feathering it through 1st 2nd and 3rd. i was cutting 2.1 60's. So i'd say with that power level and dr's you should definatly be well in the 12's. and also i just realized that we have the same crappy suspension. tenzo-r baby haha.</TD></TR></TABLE>
the track was super shitty and cold. i was spinning with 50-60% gas. but i will try a 3500-5000rpm luanch and see what happens
Old Oct 23, 2006 | 02:17 PM
97gsrki's Avatar
Default Re: (komat)
yeah i hear ya. it looked like as soon as your tires started spinning you shifted(maybe you werent) but if you were then try to ride out the gears a little longer feathering it. Personally i think its way more challenging trying to go down the track with a 400+ whp car on street tires than it is on slicks. Atleast as far as technique. Good luck next go at the track the car sounds sick
Old Oct 23, 2006 | 05:17 PM
Moshimoto racing's Avatar
nice set up, and good luck with the slicks on your next run.
Old Oct 23, 2006 | 07:05 PM
kangaroo's Avatar
I have azenis 615's to and they hop like crazy off the line.
I don't think there to good for drag racing.
There side walls are to stiff.
Mhollaek9
Aug 11, 2007 08:57 PM
civicjdmb16a
Jun 23, 2007 12:51 PM
todaspecsi
43
Apr 27, 2004 06:57 AM
chuckd05
Mar 24, 2003 01:49 PM
BoM
10
Jan 22, 2002 08:15 PM
