steering wheel removal
Old May 5, 2002 | 09:14 AM
importneeds's Avatar
Default steering wheel removal
does anyone know how to remove 92-95 civic steering wheel with a airbag
Old May 5, 2002 | 10:59 AM
flat-blk-HB's Avatar
Default Re: steering wheel removal (importneeds)
there are 2 torx style screws on the sides of the wheel. T-30 torx.
you have to pull off a cover to get to them the cover is small.
take out the screws and the airbag will come out
******BE SURE AND DISCONECT THE AIR-BAG PLUG UNDERNEATH THE WHEEL THE PLUG IS YELLOW*****
there is a 19mm bolt you have to take off also. and some more litlle plugs and I think a few screws too.To take off the 19mm it is best to make the wheel lock-up to help break the nut loose. very easy
Brandon
Old May 5, 2002 | 11:20 AM
Chiovnidca's Avatar
Default Re: steering wheel removal (ED6)
Brandon
Be sure to dissable the SRS system first or you run the risk of setting off the air bags.
Civic_07
Jun 26, 2008 12:23 PM
rollercosta123
Sep 20, 2005 07:57 PM
Kid1320
81
Sep 6, 2005 09:49 AM
JamesQ
Aug 18, 2004 07:38 AM
forever slow EG6
Jun 21, 2003 10:55 PM
