b20 sleeve kits
Old Oct 22, 2006 | 10:32 AM
q8delsol's Avatar
Default b20 sleeve kits
hii
i bought b20 block and i want sleeve it
where i can buy sleeve kits online and wich is the best
i want 89mm
like this but bigger
Old Oct 22, 2006 | 12:07 PM
doood's Avatar
been there done that
Default Re: b20 sleeve kits (q8delsol)
you cant go 89mm even with aftermarket sleeves. if you want to buy sleeves and have a local machine shop install them, search for darton. if you want to send your block out and have it sleeved, search for golden eagle, erl, bensons.
NJcoupe's Avatar
You can't install them yourself, unless you have access to a machine shop.
And they don't make them in 89mm.
edit beat me too it.
Old Oct 22, 2006 | 03:09 PM
q8delsol's Avatar
Default Re: b20 sleeve kits (sticky icky)
yes i want the kits and the machine shop will install them not myself
[And they don't make them in 89mm.] i think tha maximum stroke for b20 89mm !
Old Oct 22, 2006 | 03:10 PM
q8delsol's Avatar
any online store for the kits?
Old Oct 22, 2006 | 03:15 PM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q8delsol &raquo;</TD></TR><TR><TD CLASS="quote">yes i want the kits and the machine shop will install them not myself
[And they don't make them in 89mm.] i think tha maximum stroke for b20 89mm !</TD></TR></TABLE>
usually a sleeve measurement means the size of the bore, not the stroke, you cant have a 89 mm bore, unless you have a k20
Old Oct 22, 2006 | 03:30 PM
q8delsol's Avatar
Default Re: b20 sleeve kits (Sleepy_Red_hatch)
i dont know the word but what i want the big bore for big pistons
i think if i want big pistons should i want new and big sleeve kits??
bore = sleeve kits good info
stroke = size of kits
sorry i have bad languge
but what i need the sleeve kits
Old Oct 22, 2006 | 03:35 PM
Tatakai's Avatar
bore = the diameter of the piston head
that is all you need. the size of the 'kit' will be the same as the bore.
if you have 85mm pistons, then you need 85mm sleeves.
all b-series except the b20 have an 81mm bore, i _think_ b20's is 83mm? usually you can only bore out a few mm.
Old Oct 22, 2006 | 03:50 PM
q8delsol's Avatar
Default Re: b20 sleeve kits (Tatakai)
B16a=81mm bore 77.4mm stroke 203.25 mm deck height
b20b=84mm bore 89mm stroke 211.84 deck height
b18b=81mm bore 89mm stroke 211.84 deck height
b18c(GSR)=81mm bore 87.20 stroke 212.39 deck height
so what i need 89mm sleeve or bore the same thing
Old Oct 22, 2006 | 03:59 PM
doood's Avatar
let me try to simplify this for you. the stroke of the crankshaft in a b20 is 89mm. the cylinder bores (sleeves) are 84mm. if you want big bore you would have to resleeve it then bore it to your desired specs. usually no more than 85mm on a b series if you intend to drive it on the streets.
sleeves come in one size. when your machine shop installs the sleeves they will bore the cylinders out to match the pistons you'll be using.
Old Oct 22, 2006 | 04:13 PM
q8delsol's Avatar
yes i know that
that what i want resleeve my block
i want the sleeve kits and the machine shop will bore my cylinder and put the new sleeves
that what im talking about
Old Oct 22, 2006 | 04:18 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q8delsol &raquo;</TD></TR><TR><TD CLASS="quote">yes i know that
that what im talking about </TD></TR></TABLE>
ok, as long as we're on the same page. i believe http://www.exospeed.com has the darton sleeves you're thinking about.
Old Oct 22, 2006 | 04:29 PM
q8delsol's Avatar
to bad just for b16 - b18 i cant find b20
http://www.exospeed.com/category.php?id=301
Old Oct 22, 2006 | 05:07 PM
q8delsol's Avatar
any other sites
Old Oct 23, 2006 | 07:59 AM
ExospeedAMcrx's Avatar
You cant bore out the B-series to an 89mm. That is too big. most you can go is 87mm.
the b20 is not really the best block to sleeve, it has a weaker foundation than the other b-series kits. We never use b20 blocks in our race cars, only b18 sleeved.
Old Oct 23, 2006 | 06:28 PM
q8delsol's Avatar
Default Re: b20 sleeve kits (exospeedAMcrx)
no i want just 84 sleeve for b20
any web for b20 sleeve kits?
Kim Bay
11
Aug 17, 2009 07:47 AM
onefastek9
10
Aug 7, 2008 07:23 AM
q8delsol
11
Dec 1, 2006 11:38 AM
smalls
Jul 30, 2006 12:00 PM
advance concepts
Jun 30, 2003 02:39 PM
