b20 sleeve kits
been there done that
Re: b20 sleeve kits (q8delsol)
you cant go 89mm even with aftermarket sleeves. if you want to buy sleeves and have a local machine shop install them, search for darton. if you want to send your block out and have it sleeved, search for golden eagle, erl, bensons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q8delsol »</TD></TR><TR><TD CLASS="quote">yes i want the kits and the machine shop will install them not myself
[And they don't make them in 89mm.] i think tha maximum stroke for b20 89mm !</TD></TR></TABLE>
usually a sleeve measurement means the size of the bore, not the stroke, you cant have a 89 mm bore, unless you have a k20
Re: b20 sleeve kits (Sleepy_Red_hatch)
i dont know the word but what i want the big bore for big pistons
i think if i want big pistons should i want new and big sleeve kits??
bore = sleeve kits good info
stroke = size of kits
sorry i have bad languge
but what i need the sleeve kits
bore = the diameter of the piston head
that is all you need. the size of the 'kit' will be the same as the bore.
if you have 85mm pistons, then you need 85mm sleeves.
all b-series except the b20 have an 81mm bore, i _think_ b20's is 83mm? usually you can only bore out a few mm.
Re: b20 sleeve kits (Tatakai)
B16a=81mm bore 77.4mm stroke 203.25 mm deck height
b20b=84mm bore 89mm stroke 211.84 deck height
b18b=81mm bore 89mm stroke 211.84 deck height
b18c(GSR)=81mm bore 87.20 stroke 212.39 deck height
so what i need 89mm sleeve or bore the same thing
let me try to simplify this for you. the stroke of the crankshaft in a b20 is 89mm. the cylinder bores (sleeves) are 84mm. if you want big bore you would have to resleeve it then bore it to your desired specs. usually no more than 85mm on a b series if you intend to drive it on the streets.
sleeves come in one size. when your machine shop installs the sleeves they will bore the cylinders out to match the pistons you'll be using.
Re: b20 sleeve kits (sticky icky)
yes i know that
that what i want resleeve my block
i want the sleeve kits and the machine shop will bore my cylinder and put the new sleeves
that what im talking about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q8delsol »</TD></TR><TR><TD CLASS="quote">yes i know that
that what im talking about </TD></TR></TABLE>
ok, as long as we're on the same page. i believe http://www.exospeed.com has the darton sleeves you're thinking about.
to bad just for b16 - b18 i cant find b20
http://www.exospeed.com/category.php?id=301
1 Post
You cant bore out the B-series to an 89mm. That is too big. most you can go is 87mm.
the b20 is not really the best block to sleeve, it has a weaker foundation than the other b-series kits. We never use b20 blocks in our race cars, only b18 sleeved.
Kim Bay
11
08-17-2009 07:47 AM
q8delsol
11
12-01-2006 11:38 AM
