whats you opion on turbo manifolds with the wastegate flange on one exhaust port??
Old Oct 22, 2006 | 10:19 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default whats you opion on turbo manifolds with the wastegate flange on one exhaust port??
ive been doing a little looking around and it seems like most of the manifolds are like this but i heard they boost creep.
how many of you guys run a manifold like this?
how do you like it and does it creep on you.
thanks guys i just need a little heads up
Old Oct 22, 2006 | 07:42 PM
vteg98's Avatar
Default Re: whats you opion on turbo manifolds with the wastegate flange on one exhaust port?? (stocker2shoc
Chuck Norris clogs the toilet when he pisses.
Old Oct 22, 2006 | 07:50 PM
viet_boi_racin's Avatar
I only know of one of two manifolds that have the wastegate flange on one runner. And they're all cast. They also been known to cause boost creep. and are not the best flowing manifolds.
I'd suggest looking around for a custom made tubular manifold. They flow much better and there is so many people that can make them now, they go for fairly cheap.
Old Oct 22, 2006 | 07:53 PM
95dc2teg's Avatar
this should be in forced induction but oh well. If you want to keep ur ac stay with log manifold and get a rev hard. The wastegate is placed off of two of the runners instead of one. I have .5 psi of boost creep from it i believe which isnt anything major. Muetek also is a log manifold with good wastegate placement. I tried using this on my gsr but had trouble fitting it, so thats why i went with the rev hard.
Old Oct 22, 2006 | 07:54 PM
95dc2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg98 &raquo;</TD></TR><TR><TD CLASS="quote">Chuck Norris clogs the toilet when he pisses.</TD></TR></TABLE>
why even post?
Old Oct 26, 2006 | 10:35 AM
vteg98's Avatar
cuz i felt like it.... why even post what you did?
Old Oct 26, 2006 | 10:38 AM
95dc2teg's Avatar
because i had something useful to say, bitch
Old Oct 26, 2006 | 01:59 PM
vteg98's Avatar
all right big man, whatever you say chocolate hot dog
Old Oct 26, 2006 | 02:03 PM
Wayne_Curr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg98 &raquo;</TD></TR><TR><TD CLASS="quote">all right big man, whatever you say chocolate hot dog</TD></TR></TABLE>
You are worthless, just leave.
Old Oct 26, 2006 | 10:45 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 &raquo;</TD></TR><TR><TD CLASS="quote">ive been doing a little looking around and it seems like most of the manifolds are like this but i heard they boost creep.
thanks guys i just need a little heads up</TD></TR></TABLE>
As said above, this is better suited in the FI section. But you might get flamed big time for this kind of question over there. Soooo I'm here to help haha.
Manifolds with the wastegate on only one runner is a poorly designed manifold...period. I <U>had</U> one (drag), and it creeped so I hated it and got a better one. When buying a manifold, make sure that the wastegate is centrally located where all of the runners meet. This gives you the best results.
wtsapexipowerfc
May 29, 2010 07:58 AM
iNERtIA
May 18, 2008 06:18 AM
1JDMDOMINICAN
Nov 28, 2005 01:35 PM
zulustypes
Jan 26, 2005 02:52 PM
DENCIO
Sep 21, 2003 07:31 AM
